Closing Off Duct Work - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By yuri
Old 03-19-2020, 03:26 PM   #1
Rewards Points: 170
Closing off duct work
My wife likes the ac cold over summer And then likes no heat over winter. What are some of the ways to control how much air that one room gets. It is a separate run that is right above the furnace.
Should I run a second duct line to her room and have an in-line shutoff? Or maybe a powered inline booster? What would you recommend?
hellothere123 is offline   Reply With Quote
Old 03-19-2020, 03:31 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 240
Re: Closing off duct work
If she needs more air to her room and you can physically install another line then that is the best idea.
Inline boosters are noisy and use a lot of elec $$ and rarely do a good job.
In the Winter just shut off the manual damper which you should have installed in it.
Gwing21 likes this.
Old 03-19-2020, 03:33 PM   #3
Rewards Points: 170
Thank you. Will do. Maybe we can start fighting about something else instead 😆
Old 03-19-2020, 03:59 PM   #4
sktn77a's Avatar
Rewards Points: 1,028
You may need to add a return to her room (if it doesn't already have one) to permit the extra airflow into the room.
sktn77a is offline   Reply With Quote
