Chimney Liner Diameter - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2020, 10:48 PM   #1
Rewards Points: 2
I plan on purchasing the
Weil-McLain 109K BTU 82.1% AFUE Hot Water Gas Boiler Power V.
Model: CGt-5-PIN Item Number: 49503
I need to reline my chimney. I am wondering what diameter kit to purchase.
Thanks for any help.
mmtta is offline   Reply With Quote
Old 06-30-2020, 07:53 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 212
Re: Chimney Liner Diameter
Try get the installation manual for it and there may be rules for the chimney that they want you to use.
It has to do with the height of the chimney also. If you are going to add a hot water heater to that chimney then there are very specific rules as to how to attach it and where.
The install manual should help you.
