Chimney Caps ? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2015, 07:22 PM   #1
Rewards Points: 1,254
chimney caps ?
i think i need a new one. the one up there now looks like this one. el-cheapo.
http://ecx.images-amazon.com/images/...iL._SX300_.jpg
while i am not opposed to getting another one of these, as the price is right.
if these are not that good, and/or i can get one that at least looks nicer. and doesn't cost a lot.
suggestions ?
oh, this is for the gas furnace and HWH, and i think its 4", but could be wrong.
and its a pipe sticking up from the brick chimney.
Fix'n it is offline   Reply With Quote
Old 10-18-2015, 07:29 PM   #2
ooops. double post. please delete.
Old 10-18-2015, 08:36 PM   #3
Rewards Points: 80
That's a fresh air rain cap. You'll want to make sure that there's a mesh on it to keep birds and the like out.
Cheers!
supers05 is offline   Reply With Quote
The Following User Says Thank You to supers05 For This Useful Post:
Fix'n it (10-18-2015)
Old 10-18-2015, 10:33 PM   #4
Rewards Points: 18,982
https://www.google.com/search?q=4%22...odT_ULvQ&dpr=1
Old 10-19-2015, 04:25 AM   #5
An old Tradesmen
Rewards Points: 9,478
Shanty cap. Commonly used on chimneys/flues of older houses around here.
Old 10-19-2015, 07:45 PM   #6
thanx, fella's. i didn't know those terms. but this has got me to thinking, i could make my own. i'm going to chew on this, and keep an eye out for something interesting that could be used as a cap. then see what comes of it.
thanx
Old 10-19-2015, 08:42 PM   #7
Rewards Points: 1,956
If you are going to go through the trouble of making one, make it out of Copper.
ChuckF. is offline   Reply With Quote
Old 10-19-2015, 09:37 PM   #8
Rewards Points: 80
They are made out of aluminum here. Depending on where you live, it may have go be certified for gas venting
Cheers!
Old 10-19-2015, 11:42 PM   #9
Rewards Points: 234
I am making assumptions about circumstances behind your post, but why not spray paint the one you are already using to make it look good, or repair it as necessary (since you were thinking of making your own).
If/when you get a new furnace in the future, it will likely be a higher efficiency unit with condensing exhaust, requiring a different exhaust setup.
RustNeverSleeps is offline   Reply With Quote
Old 10-20-2015, 04:23 AM   #10
An old Tradesmen
Copper will discolor and pit from the acids in the exhaust fumes.
The Following User Says Thank You to beenthere For This Useful Post:
Fix'n it (10-20-2015)
Old 10-20-2015, 08:11 PM   #11
the one up there now is rusted.
Old 10-20-2015, 09:14 PM   #12
chitownken's Avatar
Rewards Points: 510
Stainless! Once and done.
chitownken is offline   Reply With Quote
Old 10-22-2015, 03:08 AM   #13
Rewards Points: 234
I was guessing it might be rust, since mine was rusted as well. I cleaned/washed my pipe a bit and then sprayed using an inexpensive aerosol can of flat black paint that more or less matched the original color. The end result looked more than good enough from ground level, though it is uncertain how long it will last before more rust might reappear.
Old 10-22-2015, 09:27 AM   #14
Hvac Pro
yuri's Avatar
Rewards Points: 1,266
Get a aluminum one not galvanized and it won't corrode as fast. If you live in a cold climate where it can ice up then a screen can be a hazard and cause CO poisoning. There are special large bird proof types but you still need to keep a eye on them for ice buildup.
Old 10-22-2015, 07:51 PM   #15
thanx everyone.
the one up there now, its not just rusted, it has some small holes in it.
thanx yuri. never thought of the iceing up thing
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 10:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
