Changing HVAC Duct Work For The House? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By user_12345a
Old 02-20-2020, 08:15 PM   #1
Rewards Points: 6
Changing HVAC Duct work for the house?
Hello All
I am doing a whole-house renovation now, so opening some walls here and there. My contractor replaced the furnace and condenser in the house. The furnace is located in the attic, while the condenser is located on the balcony on the 1st floor.
The old furnace/condenser were both about 30 years old. I am not sure if the duct has been replaced but I assumed no.
Should I replaced the duct in the whole house? My contractor changed the duct in the attic and mentioned that the duct in the attic is the most important as there is large temperature fluctuation in the attic. He checked the duct through the house and said it's still in good condition with good insulation. He also mentioned that duct last a very long time.
I assumed when you replaced the HVAC system you would want to replace ALL the duct work? Should I replace it? Is he right? Thoughts?
My thoughts are given that I am renovating now, I should just replace it. My contractor thinks it's a waste of money.
bundybundy is offline   Reply With Quote
Old 02-20-2020, 08:32 PM   #2
user_12345a's Avatar
Rewards Points: 48
Re: Changing HVAC Duct work for the house?
If the house is heating and cooling evenly and your units are getting proper airflow*, there's no reason to re-do the ducts.
*measurements can be done to check.
u3b3rg33k likes this.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
