Caulking Fireplace? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2020, 06:23 PM   #1
Rewards Points: 68
Caulking Fireplace?
Hi All.
Well over a year ago I created this thread about my fireplace:
https://www.diychatroom.com/f17/chim...e-vent-643727/
We replaced the wood burning fireplace with a gas one. The company that did the install did a lot of air-sealing behind the fireplace and in the chase cavity. When they installed the fireplace (not an insert - they ripped out the old one and were able to install a new one from the outside-in), they were able to get it flush on one side of the hearth-opening but there was a smidge of a gap on the other side (see picture). They caulked behind the fireplace and now that we've used it for a full winter, we are feeling a draft on the side that has the gap (where my finger is). Do you think I can shoot a bead of fire-grade/high-temp caulk into that gap on the house-side of the fireplace or would there be issues in doing that?
Thanks for any advice you can offer!
Cheers,
~R
Rubespur is offline   Reply With Quote
Old 02-23-2020, 07:40 AM   #2
Rewards Points: 716
Re: Caulking Fireplace?
I’d loom through the manual for the insert.
Can’t really offer any advice if it’s ok or not with the information provided.
roughneck is online now   Reply With Quote
The Following User Says Thank You to roughneck For This Useful Post:
Rubespur (02-25-2020)
