Carrier Furnace Not Blowing Faster Enough - HVAC - DIY Chatroom Home Improvement Forum
Old 06-14-2020, 07:28 PM   #1
Rewards Points: 2
Carrier furnace not blowing faster enough
Hey all
I have high efficiency carrier. It has the large black wire on the cooling part which I understand is the fastest blower speed for cooling however it doesn't blow fats at all it's very slow. I tried the red and yellow wires and it was the same speed. What else do I have to do to get the mirror to speed up?
jordanburch is offline   Reply With Quote
Old 06-14-2020, 07:42 PM   #2
Rewards Points: 724
Re: Carrier furnace not blowing faster enough
Is there a problem your trying to solve?
Ideally you shouldn’t hear or feel airflow when the units running.
The motor could have a problem. Or capacitor.
roughneck is offline   Reply With Quote
Old 06-14-2020, 10:18 PM   #3
user_12345a's Avatar
Rewards Points: 48
A really dirty and or frozen evap coil could do the same thing.
btw - you say carrier high efficiency, if your furnace model number starts with 58 and hasn't been serviced for a while, you really should call a pro - they have issues and need to be checked regularly, see: https://www.aircoheating.ca/safety-n...at-exchangers/
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
