Carrier 58Mvp Code 25 - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2017, 09:20 AM   #1
Rewards Points: 4
I have a 2004 Carrier 58mvp 120 130btu 1HP Ecm motor, with a HK42FZ022 board. Every time there is a power bump the furnace defaults to high blower speed. The AC works but no heat, I then I have to remove the model plug, switch on sw1-6, run the test mode until code 11 flashes, slide dip switch sw1-6 back to off, replace the R wire and it works correctly, even with the model plug (PL4)removed. The blower is at the set slower speed and heat works. I have tested the model plug and resistors are OK and within spec! My way of thinking is when it is reset it works 100% turn the breaker/switch off and on BACK to the Code 25?
If this is a setup error, how do I reset the board? Could a solder joint on the board be the fault?
What I have been reading will the replacement board a HK42FZ024 solve the problem?
I have searched the internet up and down and I canít find anyone with a similar problem. HELP!
MyFixer17 is offline   Reply With Quote
Tags
58mvp , carrier , code 25
Need help diagnosing a carrier code 33 limit switch issue kevang HVAC 21 11-12-2016 10:30 PM
Carrier 9200 58MXA Code 31 jeremywbert HVAC 4 11-22-2015 08:39 PM
E2 code on Carrier OMTSTAT_3 thermostat strikeeagle HVAC 13 05-15-2011 01:42 PM
Carrier Furnace: Code 42 gonzochris HVAC 3 03-06-2011 12:32 PM
Carrier Furnace Error Code 33 s6skuzy01 HVAC 9 03-09-2009 11:42 AM
