Carrier 48TJE004---601GA NO POWER TO UNIT OR THERMOSTAT - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2020, 10:55 PM   #1
Rewards Points: 4
I am getting no power to thermostat or rooftop unit. Thermostat is a 800435-3, tested same thermostat and another room and it works perfect. Furnace Board Status LED is off. Tried resetting breaker and still have no power. I have searched around and have seen that this is sometimes caused by a limit switch?
eknsibby is offline   Reply With Quote
Old 01-21-2020, 11:46 PM   #2
user_12345a's Avatar
Rewards Points: 48
Re: Carrier 48TJE004---601GA NO POWER TO UNIT OR THERMOSTAT
Check the low voltage fuse.
If it's not that, will have to be checked with a meter - could be anything.
When the high limit is open with power to the unit, blower runs continuously.
Only old units completely shut low voltage power when limit opens.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 01-22-2020, 04:24 AM   #3
An old Tradesmen
Rewards Points: 54
That unit doesn't have the high limit in the circuit between the transformer and the board's power. Either the fuse on the board is blown, the transformers circuit breaker is tripped, the transformer is worn out, or you don't have line voltage to the unit.
Old 01-22-2020, 06:51 AM   #4
Rewards Points: 716
Check high voltage to the unit. Sometimes an emergency switch gets turned off somewhere accidentally.
roughneck is offline   Reply With Quote
