Can I Remove This Ductwork?! - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2016, 11:41 AM   #1
Rewards Points: 48
Can I remove this ductwork?!
Hey all,
I am in the process of doing a remodel and, after opening up a wall I want to remove, I see ductwork running through it. I want to eliminate this supply line as it seems to only feed one register in a small bathroom that we keep closed. I also need to relocate some returns on this wall. I will post pics in a second, they are on my phone.
cmcnick is offline   Reply With Quote
Old 01-16-2016, 12:37 PM   #2
Rewards Points: 582
well that in a long second...
Old 01-16-2016, 02:05 PM   #3
Rewards Points: 48
Couldnt upload pics from phone on app and don't want to do it from comp cuz it takes to long. Will upload later. Going to homebrew some beer.
The Following User Says Thank You to cmcnick For This Useful Post:
ben's plumbing (01-16-2016)
Old 01-16-2016, 06:01 PM   #4
Rewards Points: 80
I would say that removing it completely isn't a great idea. Relocating, sure.
Anything is possible, but that room will no longer be conditioned. If you live in a temperate area, then no prob. If you live in the south or north like some of us, that room will be unusable for times of the year. (potentially frozen pipes where some of us live)
Cheers!
supers05 is offline   Reply With Quote
Old 01-16-2016, 09:07 PM   #5
Rewards Points: 48
Here is a pic of the wall. The duct goes upstairs to a small hall bathroom. The register is closed year round. I would like to just eliminate it. The bay to the right has a hole in floor as it was a first floor return. The next bay to the right has a hole in the floor and ceiling as it was an upstairs return. The bay directly to the left of the opening has hot and cold water running to upstairs hall bath. I would like to open this from the plumbing over to the duct on the far right. That would mean eliminating the duct going upstairs, figuring out a way to redirect upstairs return, sealing plenum and floor where returns are currently, and cutting new hole and installing new collar in plenum for downstairs/upstairs return.
EDIT: Sorry pic is sideways.
Old 01-16-2016, 11:03 PM   #6
Rewards Points: 3,374
What are you doing with the return that was there?
roughneck is online now   Reply With Quote
Old 01-16-2016, 11:34 PM   #7
Rewards Points: 48
Moving it. Prong w new one on to compensate.
Old 01-16-2016, 11:48 PM   #8
Just make sure removing the duct doesn't drop you under 400 CFM/ton. Many homes suffer from oversized equipment and undersized duct.
And it's not a good idea to close off dampers. It's somewhat of an old myth that it saves money.
The Following User Says Thank You to roughneck For This Useful Post:
ben's plumbing (01-17-2016)
Old 01-17-2016, 01:50 AM   #9
Rewards Points: 676
Do not eliminate ducts! Closed registers still flow air and if you sell the house rooms without heat may be flagged during the inspection. (depends on how crooked the inspector is, if the buyer hires an inspector with a relationship with the agent you'll get off easy)
Re-route the ducts with elbows so it goes along what's left of the wall, then box it in.
For upstairs return consider putting a new return chase somewhere else in an intact wall if it lines up with an upstairs wall.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Tags
duct , ductwork , hvac , plenum , remove
How to remove shower pan? timnancyk Plumbing 17 01-11-2016 04:06 PM
Best plan for replacing removed ductwork mikhailkups HVAC 8 06-24-2015 04:36 PM
need to refinish me pressure treated deck AND remove cabot SPF - NEED INPUT Kirchf Painting 0 05-27-2015 12:19 PM
Help with Insulating Ductwork in Garage premington HVAC 10 02-21-2015 10:38 AM
need help with package unit ductwork bekind42 HVAC 15 11-04-2011 04:13 AM
