Brick Bungalow Cooling - HVAC - DIY Chatroom Home Improvement Forum
Old 06-28-2020, 11:17 PM   #1
Rewards Points: 2
Brick bungalow cooling
I have a 1950s brick bungalow with central air. The central air is also piped to finished attic. My question is this. Without making any improvements at first. What is the best and most efficient way to cool house. Attic windows open and downstairs door open to allow heavier cold air down and hotter air up and out at same time leaving a/c open to attic? Iím looking for convection efficiency options. Any help would be appreciated. Thank you
Mgarretter is offline   Reply With Quote
Old 06-29-2020, 02:20 AM   #2
retired framer
Rewards Points: 326
Re: Brick bungalow cooling
Are you planning to do this with the AC running?
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-29-2020, 02:57 AM   #3
Rewards Points: 238
Why are the attic windows open in a conditioned attic? Maybe i don't understand where these attic windows are located.
Being you have a stair well that's about as good as it gets for flowing warm air up and cooler air down. You can test this air flow, both direction and rate of flow, with a incense smoke stick.
Old 06-29-2020, 05:42 AM   #4
Rewards Points: 716
Leaving the attic windows open is increasing your cooling load, as well as your electric bill.
roughneck is online now   Reply With Quote
