Boiler Water Temp During Summer - HVAC - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By hvacman96
Old 07-23-2020, 02:58 PM   #1
samjg1's Avatar
Rewards Points: 278
Boiler water temp during summer
I have a Lennox boiler with pilot light. Just for the heck of it I checked the water temperature, and it reads 120 degrees.
Is this normal? I understand that the pilot light is always on, but does it heat the water to 120?
Thanks.
On a side note, I have two zones, but I only see one purge valve. Is this possible or should I be looking for another purge valve and outlet?
samjg1 is offline   Reply With Quote
Old 07-23-2020, 03:22 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,898
Re: Boiler water temp during summer
Originally Posted by samjg1 View Post
...does it heat the water to 120?
Do you have some other water heater there?
Many boiler owners use a smll electric WH for the summer.
(and turn off the boiler)
Old 07-23-2020, 03:50 PM   #3
Rewards Points: 152
I turn mine off once the weather stays warm.
Joeywhat is online now   Reply With Quote
Old 07-23-2020, 04:01 PM   #4
samjg1's Avatar
Rewards Points: 278
Many boiler owners use a small electric WH for the summer.
The water heater is separate.
Old 07-23-2020, 04:02 PM   #5
samjg1's Avatar
Rewards Points: 278
Does that shut the pilot also?
Old 07-23-2020, 04:12 PM   #6
user_12345a's Avatar
Rewards Points: 108
Your boiler may have been set up as hot start, meaning it keeps the water warm between heating cycles and just starts the circulater.
It's possible you have an indirect tank on it but just don't know.
If it's the former, you should shut the boiler during the summer.
I can't see a pilot alone keeping the entire boiler at 120f unless it's a very small one - it's so unlikely.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 07-23-2020, 07:39 PM   #7
samjg1's Avatar
Rewards Points: 278
How can I determine if it's a hot start?
Not indirect. Water heater is a totally separate unit.
Does shutting the boiler power switch kill the pilot light?
140,000 BTU input. Not sure if that's considered small. Not a very big house.
Old 07-23-2020, 08:02 PM   #8
Rewards Points: 108
140k is really large when it's not being used for both heat and hot water. The pilot isn't enough to keep the water as 120.
I'm not familiar with boiler wiring (much more into forced air stuff) so i can't tell you what to check in that respect, others on here know a lot more about hydronic.
If the burners cycle on without a call for heat, it's set up to stay hot.
Shutting the power will not shut the pilot but should stop the burners from coming on. You can try that to see if the boiler cools down.
In the long run you could save a lot on the heating bill upgrading the boiler - being large, standing pilot, the real world seasonal efficiency could be in the 50 to 60% range.
Old 07-23-2020, 08:34 PM   #9
Rewards Points: 152
I shut off the natural gas supply line, so yes it does.
Old 07-23-2020, 10:07 PM   #10
Rewards Points: 108
it not necessary to shut the main gas line to shut the pilot, there's normally a knob on the valve for that.
shutting the pilot in the summer saves gas, it can be worth doing but insects/duct can get in with no flame/gas flow and clog the orifice.
Old 07-24-2020, 07:46 AM   #11
Rewards Points: 108
now that i think of it, 120f is low for a boiler.
Old 07-26-2020, 05:41 PM   #12
Rewards Points: 14
is the 120' temp an actual water temp reading, or what the gauge on the boiler says?.Ive worked on lots of boilers with bad gauges.
user_12345a and samjg1 like this.
hvacman96 is offline   Reply With Quote
The Following User Says Thank You to hvacman96 For This Useful Post:
samjg1 (07-26-2020)
Old 07-26-2020, 07:28 PM   #13
samjg1's Avatar
Rewards Points: 278
It's the temp reading on the gauge.
As long as the pilot light stays on I'm just going to shut the boiler power switch.
I don't want to shut the pilot. As was said on another comment, dust, bugs, etc. can get in there and cause problems. Plus I'd have to bend down and relight the pilot again when the cooler weather comes.
Old 07-26-2020, 07:31 PM   #14
Rewards Points: 108
Yes - shut the power and see if the boiler stays hot.
Old 07-26-2020, 07:52 PM   #15
samjg1's Avatar
Rewards Points: 278
Thanks!
