BLEW UP My Trane XE1000 - Any Wiring Help? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 08:45 PM   #1
BLEW UP my Trane XE1000 - any wiring help?
I was cleaning my outdoor unit. It was pretty bad.
I took pictures the whole way through. Then when I went to put the three fan wires back in place, I apparently messed up either the brown or purple wire. Likely the purple.
When I turned the breaker on, sparks shot out of the side where the blue arrow is pointing to. I'm not sure where exactly, because the covers were back on.
Does anyone know what spades the brown & purple wire coming from the fan attaches to? It's the area where the red arrow is pointing at. I plugged the brown wire to the left/top spade on the capacitor and the purple wire to the right/top spade.
One or the other is wrong. Any ideas which?
Here's a better (before) picture of the brown wire. I'm pretty sure I've got it right. I couldn't see the purple wire in the pic, so I put it back where I THOUGHT I knew where it went. arghh.
CZ DIY is offline   Reply With Quote
Old 02-16-2010, 09:06 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
look at the sticker inside the cover should be a wiring diagragm there.im guessing you reversed the common with either the fan or compressor wire,pull out the capacitor and make sure you didnt blow out other end. hook wires back up the right way and test it ,just be ready to pull disconect if need be.might need new cap
plummen is offline   Reply With Quote
Old 02-16-2010, 10:03 PM   #3
I actually did look at it before putting the wiring back. I'm not great with schematics, but I could swear I'm doing things properly. Guess not.
Here is where I put the brown and purple wires.
And here are the diagrams. As mentioned earlier, the wires are coming from the fan motor and the problem is where they are attached to the capacitor?
Old 02-16-2010, 10:43 PM   #4
Here's a color diagram:
Old 02-16-2010, 10:51 PM   #5
You hooked it up right. Look for pinched wires going to the fan motor.
Old 02-16-2010, 11:12 PM   #6
Thanks for taking the time to look it over!!
I hooked it back up (without the covers this time) and everything is working fine! So hopefully you're right, it must have been a pinched wire or something was grounding off somewhere.
I'll put the cover back on soon. I lost my bit somewhere in the grass and can't find it, so gotta put all the nuts back on the hard way.
WOOOT!
Old 02-16-2010, 11:18 PM   #7
You have no idea how hard it was to keep from hooking it back up again without waiting for a response. Even though it was fine, I'm proud of myself for not monkeying with it without first getting confirmation from you guys.
Edit: Found that a top right corner screw was screwing into a field splice (out of site from me) from the original install. I guess now I know what that particular screw was only screwed in half-way when I took everything apart. That was causing a ground situation. I'm real happy nothing got toasted permanently.
Old 02-17-2010, 07:35 PM   #8
Houston204's Avatar
Rewards Points: 574
I like that color diagram. That was only 2 days ago and it has already traveled here... Impressive.
Houston204 is offline   Reply With Quote
Old 02-24-2010, 03:45 AM   #9
most likely sparked as the cap discharged, happens sometimes.
brewmastr is offline   Reply With Quote
Old 07-26-2016, 07:44 PM   #10
Rewards Points: 2
Talking
Re: BLEW UP my Trane XE1000 - any wiring help?
Your photo of the circuit board saved me. Rebuilt fan motor and, of course, couldn't find my note about where the black wire connected. Thanks!
obxneighbors@gm is offline   Reply With Quote
Trane XE 1500 burnt wire and wiring questions parkham HVAC 10 01-25-2010 09:01 PM
Trane XE1000 compressor not coming on line. Flathead64 HVAC 8 11-03-2009 07:29 PM
Trane heat pump wiring steven7896 HVAC 22 11-01-2009 10:01 PM
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 07:50 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
