Best Tin Snips/shears For Minimal Duct Work? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 05-13-2020, 09:02 PM   #16
Rewards Points: 248
Re: Best tin snips/shears for minimal duct work?
Originally Posted by surferdude2 View Post
This guy does it but I've seen a master do it with both snips at the same time:
Double Cut
Yep, he spends way too much time picking up and laying snips down.
Old 05-13-2020, 09:02 PM   #17
Rewards Points: 396
Originally Posted by SeniorSitizen View Post
Maybe the two snip method is a lost art and was replaced with the single snip that cuts a 1/8" curl out. I can't seem to find any vids of the 2 snip method.
I drew a straight line with a sharpie across the sections I needed to cut off and just went at it with the left-offset pair. Of course, the snap-lock tubing I'm unfolding and laying flat when cutting.
The cuts were pretty straight but wanted to curve at some points (even then it was minimal and maybe 1/16" or less off.
Have no clue on the history of tin snipping but the two cut method makes sense to prevent the metal from caving in I guess? In my case, the left hand is 'peeling' the scrap pieces away. I guess since I don't intend on using those scraps it doesn't matter as much to me. But I can see how if you want to salvage the pieces you're cutting off, you might want to be more careful haha.
SeniorSitizen likes this.
jplee3 is offline   Reply With Quote
Old 05-13-2020, 09:05 PM   #18
Rewards Points: 396
Originally Posted by tom_poconos View Post
Also, wear gloves! Sheet metal is bloody sharp and you WILL cut yourself, often without even realizing.
Good idea - I was using a pair of 7mil gloves from Harbor Freight for part of the time. There were a few instances where I got lazy and didn't wear gloves but some of the sides of the sheet metal have dulled. The fresh-cut ends are probably dangerous though but I'm shoving that part up into the adjustable elbow anyway. Fortunately, I haven't cut myself yet (AFAIK!!) but still, probably a good idea to use gloves all the time moving forward haha.
Old 05-13-2020, 10:02 PM   #19
surferdude2's Avatar
Rewards Points: 898
When cutting a straight line using cuts-left or cuts-right snips, you have to take smaller bites to keep it on line.
Tip: If you use directional cut snips upside down, they cut the opposite direction. Poor people have poor ways and that's one way they get by with less outlay on tools. I didn't do much tin work but occasionally got pushed into it... I kept my offset left snips under the truck seat... no others. They cut left, right and straight for the small jobs I did.
My neighbor in SpoCal was a retired tin knocker who built the huge dust collectors you see outside or atop some factories. He caught me using my aircraft style left cutters when I was doing the metal lath for my patio roof addition. He brought over his 16" scissor type snips and it was a WOW moment.. made the job 10 times faster and easier. He helped me for a few minutes and one time when I cut a piece free that he was holding, I said, "Be careful, that's sharp." He said, "Oh, you don't say." The fool giving advice to the master.
surferdude2 is offline   Reply With Quote
