Baseboard Heater Alternatives - Electric Only - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 01-19-2020, 09:01 PM   #16
Rewards Points: 18
Re: Baseboard Heater Alternatives - Electric Only
Where are you at? My relatives had a place in Armstrong Creek. And I know others in Oconto county.
Sent from my SM-G960U using Tapatalk
spitz1234 is offline   Reply With Quote
Old 01-20-2020, 09:36 AM   #17
Rewards Points: 1,558
Originally Posted by spitz1234 View Post
I would look at a Mitsubishi Hyper Heat ductless split. They do very well in colder climates on the heat side. And you will have some cooling on a humid July day. Set your baseboard a few degrees below your ductless setpoint.
that's what i have in my house in canada (15k btu) and it work very well over -5F to heat the entire uplevel of my 1200ft home, under -5F the electric baseboards needs to go on
spitz1234 likes this.
carmusic is offline   Reply With Quote
The Following User Says Thank You to carmusic For This Useful Post:
jp7794 (01-20-2020)
Old 01-20-2020, 09:54 AM   #18
Rewards Points: 18
The Following User Says Thank You to spitz1234 For This Useful Post:
jp7794 (01-20-2020)
Old 01-20-2020, 02:17 PM   #19
Rewards Points: 1,002
Electric resistance heaters are 100% efficient, but costly to run. An electric heat pump is cheaper to run but will not work in severe cold temps in northern Wisconsin. Then an auxiliary electric heating coil will kick on, leaving you with expensive resistance heat. A few new high tech electric heaters are cheaper to run, but the are expensive and high tech, subject to complicated problems. To heat for less money and with simplicity, you need a different fuel.
Old Thomas is offline   Reply With Quote
The Following User Says Thank You to Old Thomas For This Useful Post:
jp7794 (01-20-2020)
Old 01-20-2020, 02:42 PM   #20
Commercial. Const. ret.
surferdude2's Avatar
Rewards Points: 842
A geo-thermal heat pump installation would work but it's pretty expensive up front and the ROI takes several years even with the incentives, assistance and credits that are usually available.
Geo-Thermal
surferdude2 is offline   Reply With Quote
Old 01-20-2020, 02:55 PM   #21
Rewards Points: 1,348
with the modern mini-split style systems it's hard to make the argument for geo based on ROI.
see above post. even without the fancy inverter systems, a proper thermostat with the balance point set right will only use the electric backup to fill in, while doing the bulk of the work with the heat pump. electric aux heat is after the A coil, which means no efficiency is lost on the heat pump side of things - it can continue to operate at a 1+ COP.
u3b3rg33k is offline   Reply With Quote
The Following User Says Thank You to u3b3rg33k For This Useful Post:
jp7794 (01-20-2020)
Old 01-20-2020, 11:33 PM   #22
How much for that system compared to a standard gas furnace? Our NY house has a gas furnace that was purchased installed for less than $2500. Our FL house has a heat pump system that is not the highest tech available and it was over $6000. He didn’t ask for AC. I would use NG or if none, propane or oil.
Old 01-21-2020, 02:06 AM   #23
standard gas furnace meaning 80%? 95%? capacity? gas + AC? all heat pumps do AC.
problem with propane is depending on your individual deal it can cost the same as baseboard.
gotta get a quote unless you're going to DIY, or have an installer that will set up your gear, a 4 ton system with air handler and 5kW strip heater can be had for under $3k delivered.
The thermostat I like is around $400 with all the extra sensors (indoor, outdoor, supply/return, internet/app connectivity, etc).
Old 01-21-2020, 05:10 AM   #24
retired framer
Rewards Points: 6,028
I liked Bud's thinking on the dust, it would be worth it to pull the unit a caulk the bottom of the wall to floor. It is not just the dust but continues cold air if he is right.
Do not use flat bottom gables with scissor trusses.
Old 01-22-2020, 03:28 PM   #25
Rewards Points: 392
Originally Posted by user_12345a View Post
Sure - electric heat is 100% efficient, but the power plants sure aren't. More efficient to burn fuel directly or use a heatpump.
Transmission eats up a lot of power too. That is an easily overlooked advantage of local (roof top) renewable.
ionized is offline   Reply With Quote
