B Vent Rain Cap Question - HVAC - DIY Chatroom Home Improvement Forum
Old 05-31-2013, 02:30 PM   #1
b vent rain cap question
Hi guys,
I want to replace my hot water heater rain cap. The liner is 5". Its a single wall b vent. I know I can get these at any regular home improvement store but the cap has to sit on the existing clay chimney liner like it currently does. Right now its a piece of flashing bent at 90 degrees so it basically folds over the clay liner. Would I have to make this myself or do they sell these?
markharmon is offline   Reply With Quote
Old 05-31-2013, 02:43 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 17,900
If it's B-Vent....it is not single wall. B-Vent is double wall...
5" is kind of big for a water heater...what is the dia at the water heater?
Pictures would help....but If I understand what your describing...you have a B-Vent on your water heater that dumps into your fireplace flue...which is 5" clay pipe?
Old 05-31-2013, 05:29 PM   #3
the chimney liner is 5" because the water heater was once common vented with a furnace but that furnace is now direct vented. The hot water heater is 4" then an increase to tie into the 5" liner.
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Vent Question bigmark77 Plumbing 3 10-14-2011 09:36 AM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
