Any Idea What This Box Is? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By surferdude2
Old 05-03-2020, 10:49 PM   #1
Rewards Points: 4
Question
Any idea what this box is?
I understand from a little research that the installer used the joist for panned return. But what is this box and is it necessary? It's creating quite an obstacle to framing and sheet rocking ceiling
(not sure why pictures uploaded upside down)
Thanks!
Any idea what this box is?-20200503_234200.jpg   Any idea what this box is?-20200503_234154.jpg
sthemountain is offline   Reply With Quote
Old 05-03-2020, 11:04 PM   #2
retired framer
Rewards Points: 682
Re: Any idea what this box is?
Thanks!
That was to get to the other side of the joist in the middle with out cutting it.
He could have picked a better spot.
Can you post picture of left an right of that area,?
Will you be looking at building walls there too?
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 05-03-2020, 11:06 PM   #3
surferdude2's Avatar
Rewards Points: 906
Looks like an example of how to run a return air duct so as to be as hard to accommodate as possible. Maybe the HVAC contractor can explain/justify it... give them a call. It can be made to work but it's not going to be pretty.
surferdude2 is offline   Reply With Quote
Old 05-04-2020, 09:06 AM   #4
Hammered Thumb
Rewards Points: 152
It looks like this is at the furthest end of the return, so I don't know why they would combine one side with the other here, it would be done closer/at the handler. Why is the blocking there, the duct looks closed on the end, or was some duct removed before?
3onthetree is offline   Reply With Quote
Old 05-04-2020, 09:13 AM   #5
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,778
Looks like the blocking is one end of the duct. I would move it towards the AC lines as much as possible so your wall works out at the window opening.
123pugsy is offline   Reply With Quote
Old 05-05-2020, 09:49 PM   #6
Rewards Points: 4
Thanks for the reply. Yes, I would like to sheetrock the whole area if possible. I think they ran out of options for where to run the return based on how it was designed. If they stayed in the same bay they would have run into one of the hot runs going up or the chimney further down the wall
Old 05-05-2020, 11:09 PM   #7
retired framer
Rewards Points: 682
Any chance you could lower a the window 8" or change out for a shorter window?
figure 7-14
Old 05-06-2020, 09:15 AM   #8
Rewards Points: 906
Edit: On second thought, wouldn't work therefore deleted post
57TinkerMan is offline   Reply With Quote
Old 05-06-2020, 03:26 PM   #9
Rewards Points: 30
pix:
Corrected
diyorpay is offline   Reply With Quote
Old 05-06-2020, 07:48 PM   #10
An old Tradesmen
Rewards Points: 92
Extend the panning to the wall, and then move the jump box to the wall so its at least less inconvenient.
Tags
return air
