Angled Duct On Furnace/plenum - HVAC - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 3 Post By yuri
  • 1 Post By Bud9051
Old 03-30-2020, 01:13 PM   #1
Rewards Points: 8
Angled duct on furnace/plenum
Hi -
Wanted to hear you guys opinion on this one. New construction home, HVAC installer placed the furnace too close to the wall with the electric panel, not respecting the 36 inches code at the state I'm at. City inspector rejected, so they moved the furnace 6 inches away and angled the duct to the supply plenum - pictures attached.
Do you guys think that this would impact the system's efficiency by a good amount? My understanding is that it will impact, but not by a considerable amount.
This is bothering more than it should.
I should mention that it's a big ranch, and the baby room at the opposite side of the furnace is getting very little air flow. I ended up closing most of the duct registers. I can't help but blame it on the angle duct at the furnace,
thanks!
Angled duct on furnace/plenum-20200330_140358.jpg   Angled duct on furnace/plenum-20200330_140405.jpg
m3rcfh is offline   Reply With Quote
Old 03-30-2020, 01:37 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 162
Re: Angled duct on furnace/plenum
That offset won't affect anything. It is full size at top and bottom.
Only when it reduces does it restrict airflow. I have installed thousands of furnaces with offsets like that and had no issues.
Bondo, Bud9051 and Gwing21 like this.
Old 03-30-2020, 01:49 PM   #3
Rewards Points: 92
There is still the other issue you mentioned "the baby room at the opposite side of the furnace is getting very little air flow."
Being a new house the air flow to all rooms should have been part of the design and construction. Get them back and fix it. The solution is not "closing most of the duct registers".
Ask for the duct design, Manual D. The house should also have a manual J for heat loss and gain. That is good information for you to have as part of owning a house.
Bud
PS, I agree Yuri, that offset will have no effect on air flow.
Gwing21 likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 03-30-2020, 03:39 PM   #4
Rewards Points: 716
Those offsets aren’t going to hurt anything.
Running the furnace with most of the supply vents closed will hurt something. That issue needs to be addressed.
roughneck is online now   Reply With Quote
Old 03-30-2020, 06:19 PM   #5
Rewards Points: 8
That is very good info guys, thank you!
I am going to talk to them and see if they would send me the Manuals D and J, but duct design is one thing I don't know much about. Does fixing the farthest room problem require re-design of the ducts? I can't imagine how they would fix it
