Ameristar Vs. Carrier AC Comfort Series Opinions? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-13-2016, 01:06 PM   #1
Rewards Points: 16
Ameristar vs. Carrier AC Comfort Series Opinions?
I have started getting a couple of quotes for a new system as my current 12 year old Trane leaks R22 at the evaporator coil and has to be topped off every 7 or 8 months. My previous posts identified this issue and I finally decided to most likely just get a new unit.
I do have a quote for Ameristar 3 ton 14 SEER $3100 with Thermostat with tax/labor and 10 Year Parts/2 Year Labor Warranty. My research seems to indicate this a low end builder grade unit with some issues. It is made in China.
Another quote from a larger firm is for a Carrier Comfort Series 14.5 SEER $2938 with tax/labor and 10 Year Parts/2 Year Labor Warranty. I think for another $250 the labor warranty can be extended to 5 years. This is a high volume firm that sells many Carrier units. I have read many negative reviews of Carrier units online but am not that familiar with them and thought some of you experts may be able to shed some light. I appreciate any insight you can provide.
I am leaning towards the Carrier at this point. Supposedly prices will be going up a bit the end of the month for the Carrier. Thanks in advance!
Novice HVAC is offline   Reply With Quote
Old 06-13-2016, 01:11 PM   #2
Rewards Points: 907
Re: Ameristar vs. Carrier AC Comfort Series Opinions?
I would stay away from the Ameristar.
Bitters is offline   Reply With Quote
Old 06-13-2016, 01:49 PM   #3
Rewards Points: 123
I agree. If the difference price is majorissue get bids for other established brands (or subrand - eg Carrier makes Grandaire, Payne, Rheem/Rudd etc)) of equipment from reputable local contractors.
rkpatt is offline   Reply With Quote
Old 06-13-2016, 05:37 PM   #4
Rewards Points: 16
Is there any specific reasons to stay away from Ameristar?
Also does the contractor usually run new linesets or simply flush the lines to get rid of the R22 oil? I understand it is not compatible with the R410a Puron. I am still waiting for a written quote so this may be addressed just wanted to pose the question now.
Old 06-14-2016, 12:22 PM   #5
Rewards Points: 16
Just thought I would bump this, hoping for some more information, thanks.
Old 06-14-2016, 01:48 PM   #6
Rewards Points: 123
I don't have any additonal comments about the brand you mentioned. There are other choices that cost hardly any more $. In the long run you will better off. As far as the lineset, the original lineset could bet reused if propery flush providing it meets the size requirements of the new equipment.
Old 06-14-2016, 01:53 PM   #7
Rewards Points: 16
Thanks, that is what I wanted to know, was unclear about the lineset issue...still waiting on the formal quote.
Old 06-14-2016, 05:33 PM   #8
Rewards Points: 80
Carrier makes a decent unit. I personally like York, but it's about equal to Carrier. If I need cheaper prices, then I drop right to the discount section with arcoaire. (never for my own house that's for sure)
It's much more about the install then the brand. The work the installers do highly determains if you get a lemon or a jewel.
If it's possible, it's better to run new lineset. You'll never get all of the residue out of the lineset. I've reused them before, and those units are still chugging along, but I try to avoid it.
If you live in a very warm climate, go with a higher seer unit. (whatever you budget can handle. With each doubling of seer, you'll use half as much energy on average. Use this for your ROI) I'm cooler climate like where I live, 14SEER is just fine.
Cheers!
supers05 is offline   Reply With Quote
Old 06-14-2016, 07:02 PM   #9
Rewards Points: 272
I don't know what HVAC techs here do or have seen, but when I did my heat pump, I ran a new line set even after checking with a couple of my friends in the HVAC business. The info I got from my friends was that a new lineset wasn't needed and as long as the original lineset was cleaned ... and it didn't even need to be that clean. One friend said all he did was blow nitrogen through the old line and he's never had an issue converting from R22 to R410a.
crabjoe is offline   Reply With Quote
Old 06-15-2016, 06:38 PM   #10
Rewards Points: 16
Crabjoe, thanks for the insight....yeah am guessing they would flush out the lineset but still need to confirm.
Old 06-16-2016, 05:59 AM   #11
An old Tradesmen
Rewards Points: 8,706
Line set just needs blown out with nitrogen. Unless they see black crude on the inside walls at both ends of it.
Modifying Grundfos Comfort Series Instant hot water recirculator Mike Warner HVAC 3 03-01-2010 01:08 PM
Carrier 58MXA Series 170 trouble with temperature xrayeyes2u HVAC 5 01-24-2010 03:46 PM
Carrier 58MVP Series 140--Blower Specs--Custom Config. mogmen HVAC 12 11-01-2009 09:29 AM
Carrier Furnace Series 160 Pilot Light issue eastons HVAC 2 03-15-2009 03:26 PM
Carrier 58RAV075 series 100 vwnutman HVAC 4 01-22-2009 09:07 PM
