Air Filter Inside Furnace Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2020, 05:32 PM   #1
Rewards Points: 2
My HVAC was replaced last year and my kids have started having really bad allergies. I found out the air filter was never installed correctly and just sits inside the furnace with nothing holding it in place so air goes around it. My old unit had a retaining rod or heavy wire that snapped in place around the filter (pic in comments). Is this the best option? If so, where do I get one? I searched online but didn't find any. Of course, the installer isn't returning my calls/texts. This will really help my family.Thanks in advance
Gaguy123 is offline   Reply With Quote
Old 06-23-2020, 05:42 PM   #2
user_12345a's Avatar
Rewards Points: 48
Re: Air Filter Inside Furnace Air Handler
Can you post a picture?
No filter slot or holder inside the furnace - is it just flopping loose?
The best option is to have a 4"+ media filter cabinet installed at the return inlet of the furnace, particularly when allergies are an issue. The thick filters do a good job without restricting airflow too much -> most furnaces won't get enough airflow on a 1" merv 11+.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 06-23-2020, 08:04 PM   #3
Rewards Points: 2
I don't see a picture option on my phone but yes it's just flopping around loose. Thanks for the tip. I called a couple places and they want $400 to install a 4" inlet. I'm hoping there's a cheaper option. Have you ever seen the retaining rods inside the furnace? Can you send me a link to buy one maybe?
Old 06-23-2020, 08:30 PM   #4
Mike Milam's Avatar
Rewards Points: 66
Post a make and model number if you can't do pics.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 06-23-2020, 09:07 PM   #5
Rewards Points: 902
Are you thinking about something like this? I think the image is from Sears parts direct. I doubt anything like this would install in your furnace directly without some hardware to accompany it.
57TinkerMan is offline   Reply With Quote
