Advice For BTU For A Mini-split - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By user_12345a
Old 06-06-2020, 11:01 PM   #1
Rewards Points: 2
Advice for BTU for a mini-split
I tried using online calculators but I'm getting some very different results - can someone please advise on how many BTUs I should be getting for a mini-split AC/Heat for a single zone? I guess the real problem is that it'll be for an open-plan living/dining room with a sloping ceiling.
- ~25 x 30' = 750 ft.sq
- ceiling height at 8.5' each side, with center ridge at 18'
- climate - Western Connecticut
- a good amount of south-facing windows
cicero38 is offline   Reply With Quote
Old 06-07-2020, 03:43 PM   #2
user_12345a's Avatar
Rewards Points: 48
Re: Advice for BTU for a mini-split
which online calculators have you tried?
the ones based on sq ft are useless.
https://www.loadcalc.net/
If the system will be the primary source of heat, sizing it will be a balancing act.
You may only need only 9 to 12k of cooling but more for heating.
u3b3rg33k likes this.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 06-08-2020, 07:52 AM   #3
Rewards Points: 1,700
a 12-15k btu should be ok, i have a mitsubishi 15k btu in a 1200ft home in very cold climate (quebec) and it does the work most of the time
carmusic is offline   Reply With Quote
