Add Second Bathroom Fan Vs. Install Bigger One? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-20-2016, 02:15 PM   #16
Rewards Points: 16
Re: Add second bathroom fan vs. install bigger one?
I think 70 isn't enough because the bathroom is very steamy for a long time after a shower (an hour?). That's a pretty general statement so I'll add that it's much steamier for much longer than any other bathroom I can recall having showered in.
Installing a timer might be problematic: the fan is within a can light unit that's controlled by one switch, so the timer would also leave the light on/turn it off at potentially inconvenient times.
Thanks!
jhnmath is offline   Reply With Quote
Old 12-20-2016, 02:26 PM   #17
Rewards Points: 274
Your bathroom will stay wet with any size fan if you shut the fan right after showering. There's a lot of water to evaporate from shower or tub surfaces.
The fan should be really be on a separate switch.
If not you can actually do two light switches for the fan/light both feeding the same hot; one a switch, and the second one being a timer.
If you use led bulb, the extra electricity use of running for an extra 15 minutes will be minimal.
I am not in the business of any trade or topic I give advise on. I have previous diy experience plus good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 12-20-2016, 02:58 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 9,320
I have 2 lights in my bathroom. One is the vent vent fan/light combination. The other is the light over the sink.
The vanity light is slaved off the vent fan light. I'm also using a motion sensor for the vent fan. (the people on my house have not figured out how to turn off lights)
Hence, when you go in the bathroom....you turn on the light....that turns on the fan...but it's quiet enough you don't notice it.
ddawg16 is online now   Reply With Quote
Old 12-20-2016, 03:25 PM   #19
RRH
Rewards Points: 1,332
Start with a Leviton 6260M-W push button timer.
Turn it on when you get in the shower. Also when you get out you can press it again for 10 or 20 minutes since that is how long it is recommended to fan a fan after you have finished a shower. It is important to also run it after.
Light or no steam press 10 min or heavy steam press 20 min and walk away.
Next , two fans are a bad idea for a few reasons and could work against each other sometimes.
So you a new higher cfm fan. Or I really like the very quiet Panasonic inline fans.
You could leave the current fan and add the inline fan any place in the ductwork.
Then with your current fan you can remove the cover and see the motor and the plug for it.
You will then have the option to just unplug this motor since the panasonic will be pretty powerful.
Or another option if you wanted, is to leave it to add extra cfm's as a boster fan.
Either way it should take only a couple of minutes and you can play with it and decide which is best for you.
RRH is offline   Reply With Quote
Old 01-08-2017, 05:32 PM   #20
Rewards Points: 6
Is the current 70cfm actually working? Don't assume it is because the motor makes noise. A 70 cfm fan will clear the 1000cf room in 14 minutes, if all things are correct.
Pern is offline   Reply With Quote
Tags
bath vent , bathroom , bathroom vent , bathroom ventilation , vent
Do Bathroom Doors That Open Versus Sliding Doors Make it Look Bigger? FrankL Kitchen & Bath Remodeling 1 12-24-2014 08:29 PM
Looking for awning window to install in bathroom french_guy Windows and Doors 0 05-29-2014 06:05 AM
How much would it cost (range) to install a vent on my roof for bathroom fans? jmcphers Off Topic 9 02-26-2012 05:37 AM
Need advice on what easy to install / inexpensive flooring options for bathroom floor amodoko Flooring 9 06-04-2011 04:23 PM
Bathroom Install order will_53115 Plumbing 1 09-12-2008 11:38 AM
