Add Register To Existing Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2020, 09:22 AM   #1
Rewards Points: 2
add register to existing duct
Hi folks,
We have an interior wall duct that goes through the kitchen wall and up to the attic to feed the upstairs Cape Code bdrm. We just had a minisplit installed up there, so we don't need the (sad, pretty much useless) duct up there any longer.
Instead, we want to open that duct up into the kitchen. So...remove a bit of drywall, cut a hole in the duct to we can get the air into the kitchen. I was envisioning an elbow similar to this:
Apparently I need to post at least one post before I can include links. I'm sure we all know what an elbow looks like though
to block the airflow upstairs and redirect into the kitchen.
Are we on the right track?? If so, what is the best way to attach that elbow? Ideally, I assume the elbow should slide OVER the duct to keep the air in. Not sure that's doable for this "retrofit". (Doing homework before opening walls.)
Thoughts, suggestions and experience welcomed please! Thank you!
Tara
Taf0906 is offline   Reply With Quote
Old 07-25-2020, 09:32 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 818
Re: add register to existing duct
Few more posts before you can post pictures. But, no reason you cannot re-route the air as long at the return side of the equation is addressed too.
Old 07-25-2020, 09:33 AM   #3
Rewards Points: 8
Might you need that duct for heat in the winter?
Most in wall ducts are rectangles and are barely 1/2" behind the drywall. Duct takeoffs That connect to a trunk install with bendable tabs that are inserted into a cut hole.
Now what you want to do, even if you want the heat up in the winter is possible but more information is required probably including an exploratory hole in the wall. You may need to fabricate the takeoff from sheet metal but that isn't as hard as it sounds.
The hardest part of the job will getting a clean cut for the adaption.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 07-25-2020, 10:15 AM   #4
sktn77a's Avatar
Rewards Points: 1,014
Assuming the mini-split is a heat pump, sure, that would work.
sktn77a is offline   Reply With Quote
