AC Unit WJH44800KTP0A1 Blows Air, Neither Hot Nor Cold - HVAC - DIY Chatroom Home Improvement Forum
Like Tree14Likes
Old 03-04-2020, 12:29 PM   #1
Rewards Points: 278
Wish I could be more specific on the model or the problem..
But that's it in a nutshell..
In the one pic of the circuit board, I remember changing the marked part on my daughters way back when...
I realize the details are sketchy, but I stand ready to give any further info..
Thanx
AC Unit WJH44800KTP0A1 Blows Air, Neither Hot Nor Cold-ac-1.jpg   AC Unit WJH44800KTP0A1 Blows Air, Neither Hot Nor Cold-ac-2.jpg
Michale32086 is offline   Reply With Quote
Old 03-04-2020, 02:41 PM   #2
Rewards Points: 716
Re: AC Unit WJH44800KTP0A1 Blows Air, Neither Hot Nor Cold
Looks like that’s a package heat pump, correct?
If the blower runs it’s getting high voltage.
Is the compressor running? Outdoor fan motor?
If not test for a call to run in heating or cooling.
Does the unit have auxiliary/emergency heat? Does it operate?
roughneck is online now   Reply With Quote
The Following User Says Thank You to roughneck For This Useful Post:
Michale32086 (03-04-2020)
Old 03-04-2020, 02:52 PM   #3
Rewards Points: 716
The marked part is the transformer, which is very easy to test with your meter.
But is likely ok, since you say the blower runs.
Old 03-04-2020, 03:13 PM   #4
Rewards Points: 278
The internal fan/blower spins and blows like crazy..
The external fan just sits there..
I don't think the unit has a heat pump in it. It uses heat strips...
It DOES have EM HEAT, but that does not function... Just blows normal ambient air..
I *DID* find the large cap on it (pic marked in BLUE) and it doesn't appear to be blown.. Top is not bulged at all..
I do have a basic meter, but am not a big fan of electricity..
Which is ironic because I work on TVs for a living.. :D
Thanx for the reply..
AC Unit WJH44800KTP0A1 Blows Air, Neither Hot Nor Cold-ac-2-.jpg   AC Unit WJH44800KTP0A1 Blows Air, Neither Hot Nor Cold-ac-3.jpg   AC Unit WJH44800KTP0A1 Blows Air, Neither Hot Nor Cold-ac-4.jpg   AC Unit WJH44800KTP0A1 Blows Air, Neither Hot Nor Cold-ac-5.jpg   AC Unit WJH44800KTP0A1 Blows Air, Neither Hot Nor Cold-meter.jpg
Old 03-04-2020, 03:24 PM   #5
user_12345a's Avatar
Rewards Points: 38
You have a heatpump for sure though it may not have been wired/setup properly.
When the heat worked, did the outdoor fan come on?
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
The Following User Says Thank You to user_12345a For This Useful Post:
Old 03-04-2020, 03:45 PM   #6
Rewards Points: 278
Thanx for the reply... It's worked fine for the last 3 or so years.. It's only recently it's crapped out..
I am not sure if the outdoor fan came on with the heat.. I don't think so...
Old 03-04-2020, 03:59 PM   #7
Rewards Points: 716
Check the control wiring. You definitely have a heat pump, which isn’t really a device you install on the unit. A heat pump is the unit.
You’ll have to check the control wiring to determine if it’s wired correctly.
Old 03-04-2020, 04:01 PM   #8
Rewards Points: 278
Since it worked for years, can't I assume it's wired correctly??
Old 03-04-2020, 04:05 PM   #9
Rewards Points: 716
Not if it’s never run the compressor in heating mode.
To determine what’s wrong you’ll be testing the control circuit anyway. You’ll have to check it live to see what’s calling.
See if you have a heating call when the thermostat is calling for heat.
Old 03-04-2020, 04:11 PM   #10
Rewards Points: 278
Originally Posted by roughneck View Post
Not if itís never run the compressor in heating mode.
To determine whatís wrong youíll be testing the control circuit anyway. Youíll have to check it live to see whatís calling.
I assume I use the meter for that?? Can ya walk me thru it??
Old 03-04-2020, 04:12 PM   #11
Rewards Points: 716
Yes, check and see what’s calling on the low voltage terminal block.
Old 03-04-2020, 04:13 PM   #12
Rewards Points: 278
And it has run as a heater the past few winters OK....
We don't get MUCH call for it here in FL, but it has run the heat just fine up until a couple weeks ago..
Old 03-04-2020, 04:25 PM   #13
Rewards Points: 278
I should also note that right before it crapped out, it would be running fine, the outer fan was spinning fine and then it would rumble REALLY loud and shake the house..
Like the fan got off center and shook really bad..
It happened for an hour or so.. We thought it was the military doing test bombing runs in our area as it had been reported they would be..
Old 03-04-2020, 05:11 PM   #14
Rewards Points: 716
Could have been a few things that caused that, but more diagnostic work will be needed going forward.
Old 03-20-2020, 09:06 AM   #15
Rewards Points: 278
Apologies for getting away from this... With everything going on and having 3 big projects in the works, plus the weather not really being that bad, I got tied up...
We're shut down at work for the next few weeks due to the pandemic scare so I have some time on my hands..
I have found out that this unit IS indeed a Heat Pump unit.. I found the manual!! :D
As I mentioned, the capacitor feels OK.. Not blown or anything..
But I have the whole day to spend checking things with my handy dandy trusty dusty voltmeter... It's funny I repair TVs for a hobby and work around hi-voltages on a daily basis.. But playing around with this capacitor gives me the willies..
"Why do they call it 'the willies'?? The should call it 'the Sams'.."
-Kevin Spacey, OUTBREAK
:D
