AC Unit Buzzing And Humming But The Fan Not Working - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By yuri
Old 07-01-2020, 11:23 PM   #1
Rewards Points: 58
AC unit buzzing and humming but the fan not working
My Trane unit is about 12yrs old. It was working great until a couple hrs ago. Suddenly I can hear that the unit is on by its humming buzzing sound so I kept manually rotating the fan with a stick then it started running again. But I felt that it was still blowing warm air through the vent.
I have another unit next to it and I can tell the fan's not rotating as fast on the troubled one. Would that be the reason for the warm air? I don't think the freon leaked out suddenly 'cuz it was blowing cold air just a couple hrs ago before the fan stopped.
Will this require a new capacitor and is it an easy DIY job?
jayre is offline   Reply With Quote
Old 07-02-2020, 07:13 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Re: AC unit buzzing and humming but the fan not working
Are you comfortably safe around electricity? If so, I would check the capacitor.
Capacitors are easy enough as long as you drop power to the unit and take a picture of the connections so they go back the same way.
Old 07-02-2020, 08:57 AM   #3
Rewards Points: 58
Thanks! It looks like I can just take pic first then replace it the exact same way. If I turn the AC switch off in the circuit box, it should kill all the power for me to safely work, right?
Old 07-02-2020, 10:29 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 210
As long as it is the correct circuit. You can start the AC and THEN flip the switch and see if it stops.
Capacitors have a rating like 30mfd/5mfd 370 VAC or 440 VAC and you need to match the rating.
You cannot use a 370 VAC in place of a 440VAC.
Windows on Wash likes this.
