AC System Size - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2019, 07:36 PM   #1
Rewards Points: 6
Question
AC System Size
I have an old home Central AC. The decal on the side of the outside unit is faded so I cannot read it at all. I can however read the decal on the compressor itself. If the actual compressor is a 2 ton unit, does that mean that the system is a 2 ton system?
DeepCon3 is offline   Reply With Quote
Old 02-27-2019, 07:40 PM   #2
Rewards Points: 80
Re: AC System Size
Probably.
What's the exact model number and make of the compressor.
Sometimes you'll be able to read the model number off the faded label when shining light at shallow angle.
Cheers!
supers05 is offline   Reply With Quote
Old 02-27-2019, 09:10 PM   #3
Rewards Points: 6
Re: AC System Size
Copeland CR24K6-PFV-270
Old 02-27-2019, 09:24 PM   #4
Rewards Points: 80
Re: AC System Size
Yeah it'll be rated at 2 tons.
It'll do 2.75 tons at 100*f condensing. It's a decent compressor.
Cheers!
Old 02-28-2019, 09:50 PM   #5
Rewards Points: 6
Re: AC System Size
Thanks!
Tags
ac size
sizing hidden1 HVAC 11 12-10-2014 01:33 PM
A strange one - polybutelene piping used in radiant heating system GordCooper Plumbing 4 03-13-2012 10:09 PM
Need Help Buying a Sediment and Water Softener System. vpr80 Plumbing 10 02-23-2012 10:26 AM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
