AC Options - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2015, 05:54 PM   #1
Rewards Points: 626
AC options
So we bought a vacation home that was built in 1998 and has hot water baseboards and a new boiler. We want to add a/c. It's a pretty typical 3 bedroom ranch, about 1600 sq ft, with a full finished basement with 2 more bedrooms, living room and another kitchen. I'm not really concerned about the basement, because it stays very comfortable down there in summer. There's no headroom to put in a central a/c unit in the basement and add a trunk and ducts. There's a central closet on the main level that could house a central unit, but that would probably mean running ductwork in the attic. It wouldn't be that bad, it's all blown in insulation and trusses so it's accessible. I know that's not ideal, and we are in Michigan so we aren't in the southwest where the attic gets thousands of degrees. Or the ductless mini split units in the 3 bedrooms and living room, but the wife does not want to see the insulated lines running all over the outside of the house. Maybe run the lines in the attic? I haven't contacted a contractor yet because we don't actually get possession for a couple more weeks, but I like to be as informed as possible, so any suggestions would be appreciated. I don't expect specific answers without seeing it of course.
taylorjm is online now   Reply With Quote
Old 12-21-2015, 06:10 PM   #2
Rewards Points: 907
Yes I would look into a mini/split. They do make covers for the line set.
Bitters is offline   Reply With Quote
Old 12-21-2015, 06:14 PM   #3
Rewards Points: 676
Mini-split. keep ducts out of attic, mini is infinitely more efficient than a crap attic system.
the lines can be covered i think.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 12-21-2015, 06:39 PM   #4
Rewards Points: 626
Yeah, but the covers for the lineset look like someone stuck vinyl downspouts on the side of your house. It's a waterfront house and would be on the water side, and the wife said no way is she going to have white vinyl running all over the side of the house. Any other options for the linesets?
Old 12-21-2015, 06:49 PM   #5
Rewards Points: 3,370
Multi head mini. Many can be run, so you can run multiple heads off one main lineset. Which means only one line gets run on the outside of the house.
We sell a load of Samsung equipment that looks great when it's installed.
http://www.samsung.com/au/air-conditioning/
roughneck is online now   Reply With Quote
Old 12-21-2015, 06:51 PM   #6
Rewards Points: 626
Thanks for the suggestion, but whether it's one lineset or all 4, the boss isn't going to go for having the covers running across the entire length of the house. Can you imagine this running across the entire length of a waterfront home? Yeah, she's not gonna go for that! lol
Old 12-21-2015, 07:05 PM   #7
Run one up into the attic. Then you can distribute into the rooms once you get up there out of sight. You can do ducted units (like little air handlers), wall mounts, baseboards, whatever works best. And if running the lineset down an interior wall is easier, that's fine too because you can install mini condensate pumps on the units that mount inside and pump the condensation wherever you need to dispose of it.
Old 12-21-2015, 07:08 PM   #8
These are Mitsubishi commercial units, but it's the only pic I have available. Each set does over 10 indoor units with only a single line going in on the outside. So it gives you the idea of what's possible.
Old 12-21-2015, 07:09 PM   #9
Rewards Points: 907
I think you are going to have to go with the Boss on this one.
Old 12-21-2015, 07:14 PM   #10
Rewards Points: 626
Can you mount the mini split air handlers right at the ceiling, then run the linesets in the attic? The one main one that would go to the outside unit would be on the side of the house, so she's fine with that. Will the linesets condense and get insulation wet? I know each unit has drain lines and to have that line run outside the house and drip down would be fine I think.
Old 12-21-2015, 07:30 PM   #11
Rewards Points: 626
I was also considering something like this. It's a wall mounted unit, and you drill two 8" holes to the outside for venting, and use an existing electrical outlet. (draws 8 amps I think, and nothing else would really run on each circuit)
It's something that I could do myself, so would save a ton on labor. What are your thoughts?
http://www.kingersons.com/wallaircondtioner.html
Old 12-21-2015, 07:30 PM   #12
The line would be insulated per manufacturers instructions. So it wouldn't condense and drip.
Where you mounted the indoor units would depend on what style of unit you chose. There are pumps that fit inside the indoor equipment, that pump the condensation out so units don't have to be on an outside wall.
Old 12-21-2015, 07:51 PM   #13
I honestly wouldn't want them hanging on my inside walls anymore then I'd want linesets running all over outside ones. Plus they could be noisy, plus if you ever went and installed something else you'd have 8" holes all over the place to seal up.
The Following User Says Thank You to roughneck For This Useful Post:
taylorjm (12-21-2015)
Old 12-21-2015, 09:20 PM   #14
Bob Sanders's Avatar
Rewards Points: 2,536
I have never been really wild on the idea of mini splits either. Great little machines mind you but to have all that ugliness in plain site when you've worked so hard to make everything look good... It just doesn't sit right with me. Just my opinion though.
Bob Sanders is offline   Reply With Quote
Old 12-21-2015, 09:35 PM   #15
The options have really exploded for mini splits in recent years. You can have everything from conventional wall hung indoor units to full ducted air handlers that are completely out of sight.
My dream system, if money were no object, would be a Samsung DVM-S heat recovery system (big brother to a conventional mini) with various indoor heads spread through the house. Wall mounts in the basement, ducted low static fan coils mounted to the ceiling joists in the basement for the first floor, same in the attic for the second floor, ceiling cassettes in the shop. All capable of running simultaneous heating and cooling off a single outdoor unit.
Exploring Options ... dighog Electrical 6 07-28-2014 11:24 PM
Inexpensive Siding options that that aren't Vinyl or Metal GumbyMan Building & Construction 15 01-06-2013 12:01 PM
Recommendations for heating and cooling options for my home? daluu HVAC 2 12-23-2012 02:31 PM
Shower options Chilidog Tiling, ceramics, marble 3 06-06-2012 05:28 PM
Maytag dishwasher has 5 cycles and three options. only one cycle works and no options wwejj0926 Electrical 1 04-22-2012 06:54 PM
