Ac/heat Pump High Whistle Sound - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 12-21-2018, 03:16 PM   #16
Rewards Points: 1,004
Re: Ac/heat pump high whistle sound
sounds like the vibration from the lines is being transferred to and amplified by the exterior wall the lines pass through.
The noise may be different in heating vs cooling mode, as both lines are high pressure in heating mode.
kl918 likes this.
WARNING: I am not in the business of any trade or topic I give advise on. Follow the advice I post at your own risk. I only have previous diy experience plus good knowledge of theory.
user_12345a is online now   Reply With Quote
Old 03-11-2019, 12:24 PM   #17
Rewards Points: 132
I came back to report the solution. The builder moved the AC/ heat pump away from under the bathroom window. I don't hear that whistle sound anymore. Not sure why the placed in the first place under the window.
2Quiker is offline   Reply With Quote
Old 03-11-2019, 06:46 PM   #18
Rewards Points: 70
Thanks for the update. It'll help others.
It sounds like it was making a very specific frequency that you can hear fairly well and isn't naturally filtered by the window very well. Sometimes moving the unit doesn't help, as the sound still goes straight through the walls. Do to still hear the same noise when standing near the outdoor unit? Did they move the lineset through a different area of the house, or did they just extend it? (moving it means that if it was probably transmitting the noise through the joists. If they just extended it, the extra length may be acting like a muffler/ vibration absorber. It's not much, but just enough in your case. This has come up in very short linesets before.)
It was probably one of those manufacturing oddities and isn't really converted under warranty but will drive you up the wall. I'm glad it worked out in your case.
Cheers!
supers05 is offline   Reply With Quote
Sump Pump Running Constantly - Never Ending Water! seldom Plumbing 7 12-08-2015 07:59 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
sewage pump high water alarm tessrea Plumbing 8 09-11-2011 01:59 PM
Sump pump stops pumping in high water MrKrabbs Plumbing 3 08-10-2011 05:00 PM
A/C Transformer buzz - high pitched sound ComfortSD HVAC 5 12-27-2008 01:37 PM
