AC Fan Motor Vibration And Shutdown Noise. Video Included. - HVAC - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By surferdude2
  • 1 Post By roughneck
  • 1 Post By beenthere
  • 1 Post By island01
Old 08-12-2020, 01:19 PM   #1
Rewards Points: 14
AC fan motor vibration and shutdown noise. Video included.
Hello,
This is my first post. I recently tried my hands at replacing the ac fan motor.(After AC person told me the fan wasn't rotating as freely as it should. And motor would probably have to be replaced soon.) I wish I took notes on how the unit sounded/vibrated before doing this.
Long story short. I replaced the motor with proper unit. Turns on. AC is cold. But I'm noticing a little bit of vibration from the motor. And when the unit shuts down I notice a noise as well. This could possible be how it was before. I never paid attention.
I've linked two vidoes 10 seconds each. The shut down noise is easy to hear. The vibration is a bit harder to see. I noticed the link video played in my browser is only 360p. But the video itself is 1080p. You can download it if you want. But even at 360p I think you can kind of notice some vibration. Again, very little.
Is this normal stuff? Should I get it looked at professionally? Thank you.
Here a link to my Google Photo's shared album.
(Apparently I can't add links to first post. So I'll post this as is and then see if I can do a second post with link.)
Update: Seems I can't reply to own post with a link. I get a message saying "You need at least 1 post to post links". Probably for security/spamming reason. Understandable. Anybody know what I need to do to add the link? Sorry, I'm new to posting on forums. Thank you.
island01 is offline   Reply With Quote
Old 08-12-2020, 02:39 PM   #2
surferdude2's Avatar
Rewards Points: 956
Re: AC fan motor vibration and shutdown noise. Video included.
Any change to a motor mounting can affect how the noise is transferred to whatever it's attached to.
Did the new fan mount the same way the old one did? If it was end bell mounted with rubber isolation pads at each end of the motor, did you use the old rubber or was new mounting rubber supplied?
Check to see that nothing was accidentally sucked into the blower wheel and throwing it out of balance. That may be where your missing glove is.
If all that checks out, you may be like me, you get so critical of things you work on that you tend to notice things that were always there and think you're the blame.
island01 likes this.
Ah, but I was so much older then...I'm younger than that now
surferdude2 is offline   Reply With Quote
Old 08-12-2020, 02:54 PM   #3
Rewards Points: 14
The motor was identical fit/size wise. So it mounted exactly as the old one did. No pads or anything. I really hope it's not abnormal to vibrate a bit. It's not jerky. Just visible vibrating a bit. I'll keep an eye on it. Thanks!
Old 08-12-2020, 02:56 PM   #4
Rewards Points: 14
Trying again to insert link to video. Again, you might have to download the vibration one. At 360p it's really hard to tell.
https://photos.app.goo.gl/AZ6icfTP8aQxe2Nj8
Old 08-12-2020, 03:41 PM   #5
Rewards Points: 14
Link worked! Also added a second vibration video. It's a little longer and closer to camera so you can really see the vibration.(Again you can see it better in 1080p. Videos are short so not that big.) Thanks
Old 08-12-2020, 05:15 PM   #6
Rewards Points: 780
May have bent the fan blade slightly removing the blade.
I don’t see too much of a vibration.
roughneck is online now   Reply With Quote
Old 08-12-2020, 05:21 PM   #7
Rewards Points: 14
Yeah, a slightly bent fan blade is what I thought it could be. I tried to be careful but my dad did grab the blade when I was trying to take it off the old motor.(To help stabilize it.) I caught him holding it and I told him to let go. He's 70+ and I don't think he held it hard. He said he didn't so I believe him. I visually inspected it and it didn't look bent. All the fans looked the same. But I guess it could be bent so slightly I can't really see it. Maybe I'll take a closer look tomorrow. Thank you!
Old 08-12-2020, 05:21 PM   #8
An old Tradesmen
Rewards Points: 140
Motor may be spinning backwards.
If its spinning counter clockwise looking down into the unit, its spinning backwards.
Old 08-12-2020, 05:44 PM   #9
Rewards Points: 14
I know air was being pushed up but I doubled checked. Blades spinning clockwise. Thanks for the suggestion though.
beenthere likes this.
Old 08-12-2020, 05:52 PM   #10
An old Tradesmen
Rewards Points: 140
Could be the blades are slightly out of balance.
Old 08-12-2020, 09:30 PM   #11
Rewards Points: 956
Stick something down through the grill until it barely touches one of the blades (power off of course) and give it the old poor mans check up for any blade bent out of alignment. Get them all the same and it should be OK.
Seems like it's not only vibrating, it's finding something in the surrounding metal that resonates with it as it passes through a certain speed when spooling up and coasting down.
Old 08-12-2020, 09:35 PM   #12
Rewards Points: 14
That's a great idea using a stick through the grill. I'm out of time for today so I'll have to do it sometime tomorrow. Thank you.
surferdude2 likes this.
Tags
hvac , noise , vibration
