AC Compressor Not Kicking On - HVAC - DIY Chatroom Home Improvement Forum
Old 06-06-2019, 05:20 PM   #1
Rewards Points: 115
AC compressor not kicking on
I have an in wall Kenmore 240v unit. When I turn it on all functions work but the compressor doesnt kick on. It buzzes for a while every couple minutes and eventually works. What should I look for?
panteramatt is offline   Reply With Quote
Old 06-06-2019, 06:15 PM   #2
Rewards Points: 382
Re: AC compressor not kicking on
Check the run capacitor and wires to the compressor
ohm out the compressor windings (https://www.lennoxpros.com/news/the-...ase-compressor)
If it doesn't start with good windings and a good capacitor, you can try a hard start kit like http://www.supco.com/eclass.htm.
If it doesn't start with a hard start, the compressor is finished and it's wise to replace the unit.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 06-12-2019, 09:18 AM   #3
Rewards Points: 2,996
Did you find the problem?
roughneck is online now   Reply With Quote
