4 Ton Coil With 3.5 Ton Compressor - HVAC - DIY Chatroom Home Improvement Forum
View Poll Results: Should I get a 4ton coil to match with 3.5 ton compressor
Yes 0 0%
No 0 0%
Voters: 0. This poll is closed
Old 07-14-2020, 03:39 PM   #1
Rewards Points: 2
4 ton coil with 3.5 ton compressor
Is it advisable to install a 4 ton coil with a 3.5 ton compressor? Would like to have pros and cons.
Sunil is offline   Reply With Quote
Old 07-14-2020, 03:47 PM   #2
An old Tradesmen
Rewards Points: 60
Re: 4 ton coil with 3.5 ton compressor
Usually gets higher efficiency.
May get a slightly higher capacity.
Might not get as much moisture removal.
Old 07-14-2020, 04:55 PM   #3
user_12345a's Avatar
Rewards Points: 48
Coil tonnages are nominal and usually for 13 seer matches.
Make sure the coil being used is an ahri approved match to the condenser.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 07-14-2020, 06:03 PM   #4
Missouri Bound's Avatar
Rewards Points: 4,172
Hmm....you may have to speed up the blower.
And if this makes the unit oversized then you will most likely have excess humidity since the run times will (probably) be shorter.
But will it work......most likely.
Do you want it your way or the right way?
Old 07-16-2020, 08:37 PM   #5
sktn77a's Avatar
Rewards Points: 1,020
Oversizing the coil 1/2 ton will get you a little more efficiency at the expense of dehumidification. Depends what's more important to you
sktn77a is offline   Reply With Quote
