This Is A 2 Ton Condenser Right? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 06-05-2020, 06:05 PM   #1
Rewards Points: 792
This is a 2 ton condenser right?
model #: 2TWB0042A1000AA
form8829 is offline   Reply With Quote
Old 06-05-2020, 06:36 PM   #2
Rewards Points: 764
Re: This is a 2 ton condenser right?
3.5 ton
roughneck is online now   Reply With Quote
Old 06-05-2020, 10:10 PM   #3
dj3
Rewards Points: 306
You see the number 42 in the model number?
Divide it by 12 to get 3.5 ton.
LS-6 likes this.
dj3 is offline   Reply With Quote
Old 06-06-2020, 08:19 PM   #4
Rewards Points: 792
dj3,
so, you just get the 2 digit number in the middle and divide it by 12? is that the standard way to do it for every hvac system?
Old 06-06-2020, 09:49 PM   #5
Rewards Points: 764
There is 12,000 BTU per ton of cooling.
The 2 or 3 digit number buried in the model number is the total BTU of the condenser, in most cases.
12 is 1 ton
24 is 2 ton
30 is 2.5 ton
36 is 3 ton
And so on.
Old 06-06-2020, 10:15 PM   #6
dj3
Rewards Points: 306
Originally Posted by form8829 View Post
dj3,
Yes, now that you know this, you can tell how many tons in every unit, unless of course the numbers have faded.
Old 06-07-2020, 12:07 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 244
Technically the tonnage is based on the compressor and you can have a 22-23,00 BTU compressor in a 2 ton unit but that is just info a few techs know.
PLUS compressors are rated in HP not BTU's.
Old 06-07-2020, 12:12 PM   #8
DIY Veteran
LS-6's Avatar
Rewards Points: 62
I just had a 3 ton unit installed in my home and the number was 36, like others said it's divisible by 12 for 36,000 BTU's.
My old unit that leaked out the freon through the A coil I think was 2.5 ton, but it was 36 years old.
This 3 ton unit works great and doesn't run as much as the 2.5 ton unit. Better to go with a tad more than you need for those 100+ degree days.
LS-6 is offline   Reply With Quote
Old 06-07-2020, 12:26 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 244
The installer should have done a heat load calc and sized it according to your house and insulation type etc.
Your old unit had a worn compressor and that is why it ran longer. It may have been a 3 ton if you don't know the model # so don't worry.
If you are in a very humid area a smaller unit runs longer and de-humidiifes better. Extra capacity in Arizona and Texas is a good idea IMO.
Old 06-07-2020, 12:29 PM   #10
Rewards Points: 764
Bigger is not better when it comes to hvac. Advising to blindly put in a larger unit isnít wise, as your new 3 ton unit could get connected to undersized duct and never put out 3 tons.
You want the unit to run, itís most efficient that way.
Old 06-07-2020, 12:36 PM   #11
DIY Veteran
LS-6's Avatar
Rewards Points: 62
Originally Posted by roughneck View Post
Bigger is not better when it comes to hvac. Advising to blindly put in a larger unit isn’t wise, as your new 3 ton unit could get connected to undersized duct and never put out 3 tons.
You want the unit to run, it’s most efficient that way.
My 3 ton unit is suited for the 1900 square feet of my home and so is the duct work. 2.5 ton is not quite enough.
It also depends on how well one insulates the cold line from the unit to the A coil. I noticed it's not insulated inside the unit but I insulated it with 1/2" ID foam which is 11/16" ID vs the 3/4" which is 7/8" ID and too lose of a fit. Then I wrapped the insulation with 2" vinyl electrical tape. You get a nice tight fit this way for the 3/4" copper tube. We do this at work for our liquid nitrogen lines and it works very well. Not many people know this little trick.
Old 06-07-2020, 12:47 PM   #12
Rewards Points: 764
Equipment isnít sized via square footage
Old 06-07-2020, 12:50 PM   #13
DIY Veteran
LS-6's Avatar
Rewards Points: 62
That's not what my friends tell me that do this for a living.
Also I edited my post and added a useful trick of the trade.
Old 06-07-2020, 12:55 PM   #14
Rewards Points: 764
Unfortunately they are misled. Experience sometimes means youíve been doing things wrong a long time.
The suction line is supposed to be insulated. But itís not a trick of the trade in how your referring it to.
Old 06-07-2020, 01:03 PM   #15
DIY Veteran
LS-6's Avatar
Rewards Points: 62
Perhaps you can enlighten me on how to do it right now that it's done and works very well...
