Want WiFi Temp Sensor - Home Automation - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Automation
Old 11-03-2019, 01:59 PM   #1
Rewards Points: 24
Want WiFi Temp sensor
Hi I’m looking for a low cost thermometer to put in an upstairs bedroom with WiFi so I can check the temperature in my phone.
I have seen Bluetooth ones like a switchbot, but you have to get a hub too.
I don’t have the second generation Alexa because I think that one has a temp function.
Anybody that can steer me in the right direction?
Thank you.
Spring4ward is online now   Reply With Quote
Old 11-04-2019, 10:53 AM   #2
Rewards Points: 362
Re: Want WiFi Temp sensor
You just want a thermometer, not a thermostat?
We don't know your budget, but just search Amazon for "wifi thermometer" and a bunch will come up.
huesmann is offline   Reply With Quote
Old 11-04-2019, 05:54 PM   #3
Rewards Points: 24
Thanks for chiming in. I figured out my plan which I never thought of. I already have a weather station, La Crosse, and and outside sensor and it uses WiFi. I can get another sensor for that unit.
Old Today, 06:50 AM   #4
raylo32's Avatar
Rewards Points: 1,040
I just went through a similar thing trying to find a wifi temp sensor for a remote property. I ended up deploying an old wifi thermostat I had around. I just plugged it into the wall with a 24vac wall wart transformer and it is not connected to the HVAC system there... just used for temp monitoring. I even made a little stand out of some scrap wood I had around for it to sit on a shelf. That was easier and cheaper than anything else I found and works perfectly. If your LaCrosse setup isn't satisfactory try this. If you don't have an old wifi stat basic ones are very cheap.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old Today, 10:00 AM   #5
Rewards Points: 24
I had also thought about a WiFi thermostat not connected to HVAC. Luckily this la crosse is going to be ok. I got another temp/humidity sensor for 19.99. I like it so much I may buy a few to put all over, even in the basement. The funny thing about WiFi is that once you start, you want to keep getting more, lol.
Old Today, 03:52 PM   #6
Rewards Points: 2,390
They have some on Amazon for around $15, too. It is really handy to know the temperatures around your house, especially in climates where pipes can freeze.
You mean like this?
CaptTom is online now   Reply With Quote
