Satellite Dish Aiming - Home Automation - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Automation
Like Tree1Likes
  • 1 Post By adamz
Old 04-20-2020, 07:20 AM   #1
Rewards Points: 30
Satellite dish aiming
Hello everyone,
Anyone with Xplornet satellite internet?
My dish is currently aimed at Viasat 1, can I aim it to Viasat2 myself ?
Would my service improve ?
Cheers
Pauly1971 is offline   Reply With Quote
Old 04-20-2020, 08:27 AM   #2
Rewards Points: 8,349
Re: Satellite dish aiming
If your receiver is compatible with sat, you are smart enough to read and follow directions and you are authorized to use that sat I can't think of any reason why not. I installed my own Dish net without problems.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 04-20-2020, 09:17 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,682
Do you have any way to check the satellite signal as you move it? On my Bell sat the receiver has a built in aiming signal tester. I don't know if Explorenet has that, but without it I would not touch the dish.
Old 04-20-2020, 09:30 AM   #4
Rewards Points: 10,460
I have never heard of Xplorenet, so I can't comment on them specifically.
I have successfully aimed a satellite receiver. It can be frustrating - depends on the system. On the ones I have used, when in "aiming mode", receiver beeps faster as signal strength increases. But I remember one time, receiver would update so slowly that I probably scanned the dish past the satellite a dozen times before I found it.
On Xplorenet, you might be able to find more knowledgeable replies from this forum:
https://www.digitalhome.ca/forum/
SPS-1 is offline   Reply With Quote
Old 04-20-2020, 09:35 AM   #5
Rewards Points: 6
I have an app on my phone called Dish Align. It has viasat 1 but not 2 on it.
Retired guy from Southern Manitoba, Canada.
660catman is offline   Reply With Quote
Old 04-20-2020, 10:47 AM   #6
Super Moderator
joed's Avatar
The app on your phone does not connect to the dish to know if it 'hitting' the satellite. It is good to get you in the general direction but you still need a signal strength monitor connection to know if it is exact.
Old 04-20-2020, 10:54 AM   #7
Rewards Points: 6
I realize that but yes, itís a start. Both Shaw and Bell have the monitors on tv screen.
Old 04-20-2020, 05:51 PM   #8
adam
Rewards Points: 210
Just a suggestion, but before you move the dish, mark (with a permanent marker) it's current elevation and azimuth just in case you want to move it back.
mark sr likes this.
adamz is online now   Reply With Quote
Old 04-24-2020, 07:22 AM   #9
Rewards Points: 30
I downloaded an app called MITe. I will get some numbers with the app first before attempting.
