DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Home Automation (https://www.diychatroom.com/f162/)
-   -   Satellite dish aiming (https://www.diychatroom.com/f162/satellite-dish-aiming-685227/)
Pauly1971 04-20-2020 07:20 AM
Hello everyone,
Anyone with Xplornet satellite internet?
My dish is currently aimed at Viasat 1, can I aim it to Viasat2 myself ?
Would my service improve ?
Cheers
Colbyt 04-20-2020 08:27 AM
Re: Satellite dish aiming
If your receiver is compatible with sat, you are smart enough to read and follow directions and you are authorized to use that sat I can't think of any reason why not. I installed my own Dish net without problems.
joed 04-20-2020 09:17 AM
Do you have any way to check the satellite signal as you move it? On my Bell sat the receiver has a built in aiming signal tester. I don't know if Explorenet has that, but without it I would not touch the dish.
SPS-1 04-20-2020 09:30 AM
I have never heard of Xplorenet, so I can't comment on them specifically.
I have successfully aimed a satellite receiver. It can be frustrating - depends on the system. On the ones I have used, when in "aiming mode", receiver beeps faster as signal strength increases. But I remember one time, receiver would update so slowly that I probably scanned the dish past the satellite a dozen times before I found it.
On Xplorenet, you might be able to find more knowledgeable replies from this forum:
https://www.digitalhome.ca/forum/
660catman 04-20-2020 09:35 AM
I have an app on my phone called Dish Align. It has viasat 1 but not 2 on it.
Retired guy from Southern Manitoba, Canada.
joed 04-20-2020 10:47 AM
The app on your phone does not connect to the dish to know if it 'hitting' the satellite. It is good to get you in the general direction but you still need a signal strength monitor connection to know if it is exact.
660catman 04-20-2020 10:54 AM
I realize that but yes, itís a start. Both Shaw and Bell have the monitors on tv screen.
adamz 04-20-2020 05:51 PM
Just a suggestion, but before you move the dish, mark (with a permanent marker) it's current elevation and azimuth just in case you want to move it back.
Pauly1971 04-24-2020 07:22 AM
I downloaded an app called MITe. I will get some numbers with the app first before attempting.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
