Wrong Fuel Mix In Snowblower - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-23-2014, 10:17 PM   #1
Rewards Points: 26
Wrong fuel mix in snowblower
I just purchased a used snowblower from a friend, and when he was filling it up for me to test, he accidentally used a gas/oil mix instead of just regular unleaded gas. It's a 50:1 mix and probably only has about a 1/4-1/2 gallon of fuel in the snowblower. Is it safe to simply run through this mixture (and maybe dilute it some more with regular gas)....or do I need to drain all the fuel and start with fresh gas?
sockersfc2002 is offline   Reply With Quote
Old 12-24-2014, 01:59 AM   #2
Rewards Points: 1,550
Run it as is or dilute if that makes you happy. I'm just so glad you doing it and not me.
Old 12-24-2014, 05:10 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,.... Top it off with fresh gas, 'n Run it,....
That tiny bit of oil, won't hurt a thing,....
Old 12-24-2014, 06:27 AM   #4
Rewards Points: 17,912
Worst that could happen, but not likely is the plug gets fouled up. Simple fix.
Old 12-24-2014, 07:16 AM   #5
Davejss's Avatar
Rewards Points: 896
I would drain it.
Davejss is offline   Reply With Quote
Old 12-24-2014, 07:51 AM   #6
Rewards Points: 26
Thanks guys...I appreciate the comments thus far.
Old 12-24-2014, 08:21 AM   #7
Rewards Points: 3,256
I run castor bean oil mix in my 4-cycle mower. Neighbors think I'm weird when they see me sniffing the exhaust....but who cares!
zappa is offline   Reply With Quote
Old 12-24-2014, 08:55 AM   #8
Rewards Points: 270
Just put some fresh gas on top of it. I've put gas oil mix in my 4 stroke mower a few times,just to get rid of it[along with straight gas]
flhtcu is offline   Reply With Quote
Old 12-24-2014, 11:35 AM   #9
Bondo's Avatar
Originally Posted by Davejss View Post
I would drain it.
Ayuh,.... Why,..??..??
Old 12-24-2014, 11:52 AM   #10
Rewards Points: 422
I remember reading that WW1 airplanes and their caster oil use would give the pilots chronic diarrhea ....
maybe that's why your neighbors think your weird.
the handyman's secret weapon, duct tape
High Gear is offline   Reply With Quote
Fuel line repair Hardway Automotive Repairs 31 09-30-2013 08:15 AM
3 Questions: Replace propane furnace? It's age? Use dual fuel w/generator? Fruler HVAC 0 08-20-2013 08:20 AM
villager missing on cylinder 5 Bigplanz Automotive Repairs 22 08-04-2013 07:32 PM
B-12 Chemtool versus SeaFoam DrHicks Automotive Repairs 16 10-01-2012 08:57 PM
Feather lite weedeater trimmer wont start after changing fuel line! jamjr74 Tractors & Mowers 2 05-12-2012 08:20 AM
