Wood Privacy Fence Using T-post - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Oso954
Old 09-20-2018, 12:46 PM   #1
Rewards Points: 944
Wood privacy fence using t-post
As the title suggests, I want to build a rather small section of wood privacy fence. 8' wide x about 15' long. The ground is extremely Ricky and hard with lots of trees, so likely root issues as well. I can fairly easily drive t-posts in the ground, but have no desire to try to dig and set wood or metal posts.
My thought is to drive the t-posts, then get some chain link fence posts and set them over the t-post then clamp 2x4 stringers to the chain link posts and hang the wood fence as usual.
Any reason this is a bad idea?
Master Brian is offline   Reply With Quote
Old 09-20-2018, 01:17 PM   #2
Guapo
Rewards Points: 11,950
Re: Wood privacy fence using t-post
How deep is the frost line there? I understand that you don't want to dig but a 1 man auger might help.
Guap0_ is offline   Reply With Quote
Old 09-20-2018, 01:52 PM   #3
Rewards Points: 1,478
An older brother built a real nice fence with the same concept but rather than metal chain link post he discovered there is a PVC pipe that is a snug fit over the T posts. He capped the top so it would look at least 2nd class even though he fenced with cattle panels because it was just to keep the digging dog from an area. I don't recall the pipe size but it probably doesn't matter much because I suspect T post sizes vary more then PVC pipe dimensions. I do recall his being a real snug fit.
For safety, I recommend doing the ONE CALL even though it's just fence posts.
Old 09-20-2018, 02:01 PM   #4
Rewards Points: 6,989
How tall?
The real metal T-posts, in the longer length , sold at the farm stores might work for one no more than 5' tall if done on a 6' spacing. Skip the metal sleeve and attach directly to the t-post. Then simply box it in.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 09-20-2018, 02:06 PM   #5
Oso954's Avatar
Rewards Points: 1,952
The chain link posts are unnecessary cost and add unnecessary weight to the fence. If not secured to the t posts, they will be loose and allow movement.
If you are just looking to attach wood to T posts, Id look at something like this.
https://afence.com/store/T-POST-LINE-WOOD-ADP.html
Colbyt likes this.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Colbyt (09-20-2018)
Old 09-20-2018, 02:53 PM   #6
Rewards Points: 944
If you are just looking to attach wood to T posts, I’d look at something like this.
That should do exactly what I need. Thanks!
To answer the other questions.....
I believe frost is 24". I'm not at all worried about heaving or anything. Just building a small fence against a very small cabin at the lake on a primitive site. I have no running water, electricity, etc at this point. The only purpose is to somewhat protect a generator, keep barrels of water, store a few items from looking cluttered and some privacy for a shower.
Dig safe....understood, but nothing here to locate.
On the south side posts are 6' spaced. Have only set one post on east side and I'll likely slave then the same.
Need to replace rotten wood support post on porch cdnNick Building & Construction 33 05-14-2013 04:30 PM
Going to install a wood privacy fence kyomagi Landscaping & Lawn Care 16 02-22-2012 10:37 PM
Wood Fence with metal post BDestroyer8418 Building & Construction 8 09-24-2011 09:49 PM
How to install a metal fence post DEEP into the ground? boba7523 Building & Construction 14 09-20-2011 06:34 PM
