Will Low Pressure From A Valve Cause - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-06-2015, 01:15 PM   #1
Rewards Points: 604
Will low pressure from a valve cause
Water leakage around the head, causing it not to pop all the way or spray well?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 08-06-2015, 01:26 PM   #2
Rewards Points: 474
More then likely you have something inside the head that needs to be cleaned out. Sometimes if you just step on the head a few times while it is on it will correct itself.
BrowneBearLLC is offline   Reply With Quote
Old 08-06-2015, 01:28 PM   #3
Rewards Points: 604
It's a new head and line has been flushed prior to installing 7 new rain birds.
Old 08-06-2015, 01:37 PM   #4
Rewards Points: 474
Doing irrigation on a golf course for many years we would usually just have to take it apart clean everything and put it back together. If the head dose not come all the way up it will not seal and that is what is causing the water to leak around the head.
The Following User Says Thank You to BrowneBearLLC For This Useful Post:
digitalplumber (08-06-2015)
Old 08-06-2015, 01:40 PM   #5
Rewards Points: 474
I'm sorry but to answer your question yes it can. The water pressure has to overcome the spring inside to come all the way up. This is why most irrigation systems are done on a loop instead of a dead end line.
Old 08-06-2015, 02:05 PM   #6
Rewards Points: 604
Now to find them, we have no clue as to where they are!
Old 08-20-2015, 07:23 AM   #7
Rewards Points: 474
A pitchfork helps cover a lot of ground
Old 08-20-2015, 07:44 AM   #8
Rewards Points: 604
we rented one of those high end devices from a sprinkler shop, found them in no time!
Took the offending one apart and found nothing? I guess the diaphragm can look good and the solenoid make noise, but still be bad.
Going to buy an additional valve and do a transplant and see what happens.
We have 60 pounds of city water pressure at the spigot where it enters the house.
Main water valve broken/low water pressure cronic5 Plumbing 2 07-25-2013 12:31 PM
Whistling / Noisy Pressure valve on water main danielrg Plumbing 27 07-22-2013 09:23 PM
Valve sizing: choosing the differential pressure Nanimo Plumbing 0 06-20-2012 08:42 PM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
