What Is This And What Can Kill It - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By w0j0
Old 07-14-2018, 04:24 PM   #1
bryanp22's Avatar
Rewards Points: 346
What is this and what can kill it
I have the following plant all over my yard. Any idea what I can spray to kill it?
bryanp22 is offline   Reply With Quote
Old 07-14-2018, 04:53 PM   #2
Rewards Points: 1,550
Re: What is this and what can kill it
I'm not seeing a pic but glyphosate concentrate mixed according to directions usually does the job very well.
https://www.agrisupply.com/gly-star-...SABEgKigfD_BwE
SeniorSitizen is offline   Reply With Quote
Old 07-14-2018, 05:12 PM   #3
bryanp22's Avatar
Rewards Points: 346
Here is photo
Old 07-14-2018, 05:17 PM   #4
bryanp22's Avatar
Rewards Points: 346
Also will that chemical kill my grass?
Old 07-14-2018, 05:21 PM   #5
IDK what it is but if it is mixed in with the lawn or other desirable vegetation you probably already know Glyphosate can not be sprayed without killing everything. Each plant would need to be treated individually.
Old 07-14-2018, 05:22 PM   #6
Yes, it will kill your grass.
Old 07-14-2018, 07:53 PM   #7
Rewards Points: 6
Not sure what that is but this stuff does a good job at killing almost everything except grass and is easy to apply.
https://www.lowes.com/pd/Spectracide...ontrol/4736729
Make sure to note that there are a couple restrictions on the types of grass that weed stop should be sprayed on.
I'm finding that the best way to control weeds is to promote a healthy lawn through proper feeding and maintenance of pH.
Gregsoldtruck79 likes this.
w0j0 is offline   Reply With Quote
Old 07-15-2018, 10:07 AM   #8
Rewards Points: 576
IDK what this is. How big is your area...and how many of these are there ? For a small number, you can use a small propane torch to wilt (not burn) the weed. After 1-2-3 tries, the weed will exhaust its self... and die.
Cedrus is offline   Reply With Quote
