What To Use For 300ft Driveway Border - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-30-2015, 07:49 PM   #1
Rewards Points: 16
What to use for 300ft Driveway border
Greeting:
I have a duplex which sits back off the road. The driveway is a hard pack of gravel and dirt. The city wants me to square it up, cut out all the over grown grass and give it straight driveway feel all the way back to the unit. The driveway is 150ftx2 (both sides) and after we shovel cut both sides I do not want it to creep and grow all scraggily again.
Q? Economically, what can I use to border it out on both sides?
I considered composite railroad ties- BIG$$.. Please suggestions welcome
thanks
Dutch
snook123 is offline   Reply With Quote
Old 08-30-2015, 08:34 PM   #2
dd57chevy's Avatar
Rewards Points: 2,718
The city allows a gravel drive but requires you put an edging border on it ???
You indicated your priority was cost , not the labor involved . Then , probably the cheapest way would be 2x4s or 2x6s , treated or non , new or salvaged , whatever you can afford .
dd57chevy is offline   Reply With Quote
Old 08-30-2015, 08:36 PM   #3
dd57chevy's Avatar
PS: What's your location ?
Old 08-30-2015, 08:37 PM   #4
JUSTA MEMBER
Rewards Points: 4,028
That depends on what you like.
retired power poles are not very costly. Also retired wooden cross ties,
Even logs can be gotten from a log cabin supplier.
Then comes concrete blocks, or a concrete curb & gutter crew.
Old tires cut in half across the tread and bead makes a wavy edge, paint each tire a different color for a festive look.
You are limited by your imagination, go wild.
ED
de-nagorg is online now   Reply With Quote
Old 08-30-2015, 09:08 PM   #5
Rewards Points: 16
Lake Worth, Fl. The inspector want this property to be brought up to exterior code as all units on this street have receny complied with. He said he could make me resod the entire place and put in a concrete driveway but that he knows it would crush me financially.
Old 08-30-2015, 09:27 PM   #6
Rewards Points: 996
how about bricks ? you could probably find enough cheap on CL.
Fix'n it is offline   Reply With Quote
Old 08-30-2015, 10:04 PM   #7
concretemasonry's Avatar
Rewards Points: 2,716
For paver installations, very often, a edge restating is used. It is usually about 4" deep (steel aluminum or plastic) and spiked into place. It can be used for straight or curved edges.
Dick
concretemasonry is offline   Reply With Quote
Old 08-31-2015, 05:12 AM   #8
Rewards Points: 16
what about that plastic/poly lawn edging border that comes in rolls at the big box stores?
Old 08-31-2015, 05:19 AM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,614
Cheap and doesn't usually hold up for the long term.
The Following User Says Thank You to Windows on Wash For This Useful Post:
de-nagorg (08-31-2015)
Old 08-31-2015, 06:31 AM   #10
ZTMAN's Avatar
Rewards Points: 338
If you put a border in, the weeds will come back and creep over the border. If you are on a budget, after you square it up, I would just spray the edges with weed killer, put down some more gravel and apply weed killer every six to eight weeks for maintenance.
Do you have a pic of the driveway to post?
ZTMAN is offline   Reply With Quote
Old 08-31-2015, 07:12 AM   #11
Rewards Points: 1,506
Before I did anything I'd ask the city inspector for a list of acceptable material then choose the least expensive.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 09-01-2015, 11:46 AM   #12
Rewards Points: 16
I will take a picture. I like the weed killing idea with gravel add. Maybe more hassle but economical. I will get a pic.
Old 09-01-2015, 11:50 AM   #13
Rewards Points: 16
Driveway
Old 09-01-2015, 03:38 PM   #14
JUSTA MEMBER
I saw one once whose owner was in the concrete coring business.
He had lined the cores up in soldier fashion, along his 100 ft. drive, still had a weed problem, but the cores kept the drive straight.
ED
Old 09-01-2015, 06:14 PM   #15
Rewards Points: 16
Did my attached picture post?
How to repair a cracked driveway or walkway [email protected] How To Guides 8 06-15-2015 03:59 AM
concrete border to retain driveway crumbling away ideas gunner666 Concrete, Stone & Masonry 4 08-12-2014 10:04 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Driveway border filled with "wire grass" Beth777 Landscaping & Lawn Care 10 07-21-2008 10:00 PM
