What Type Of Drain Pipe To Use Near Tree - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By u3b3rg33k
  • 1 Post By Nealtw
  • 1 Post By Nealtw
Old 08-31-2018, 10:19 PM   #1
Rewards Points: 516
What type of drain pipe to use near tree
Hey All,
So to close out my last thread, I decided to daylight my downspout drain pipes onto a slope rather than come up with some other method. The challenge was that a tree was in my way, but I was able to dig below the larger roots enough that I could pass a pipe (easier said than done lol)
My question is now this. I have a bunch of solid HDPE triple wall pipe that I was planning to use, but I had some concerns that the tree roots may at some point put pressure on the pipe, and wondered if I should use PVC instead (40 or 80). That said, HDPE is much more flexible and would resist cracking if the tree was to move in wind or something... it is a pretty tight fit under the roots. Not to mention routing is a lot easier with some "give"
Either way, I figured it would be a good idea to install some cleanouts on tees. Is there a best practice for a cleanout every X feet?
Pics of my progress. Sorry it's at night but we finished up late. Thanks for any advice!
What type of drain pipe to use near tree-20180831_195300.jpg   What type of drain pipe to use near tree-20180831_195220.jpg   What type of drain pipe to use near tree-20180831_195200.jpg   What type of drain pipe to use near tree-20180831_195208.jpg
giansean is offline   Reply With Quote
Old 08-31-2018, 10:28 PM   #2
Rewards Points: 1,190
Re: What type of drain pipe to use near tree
HDPE > PVC for in-ground use any day. you're not going to beat the tree.
giansean likes this.
u3b3rg33k is offline   Reply With Quote
The Following User Says Thank You to u3b3rg33k For This Useful Post:
giansean (08-31-2018)
Old 08-31-2018, 10:30 PM   #3
retired framer
Rewards Points: 54
Those roots aren't moving enough to worry about but I would back fill that area all the way to the exit with a layer of gravel and cover that with a filter cloth so if the pipe were to break it still has a good path for the water to leave the yard.
Nealtw is offline   Reply With Quote
The Following User Says Thank You to Nealtw For This Useful Post:
Old 08-31-2018, 11:16 PM   #4
Rewards Points: 516
How about cleanouts? Overkill or actually useful? It will probably be about 35ft of pipe all told.
Old 08-31-2018, 11:32 PM   #5
retired framer
Rewards Points: 54
Over kill never hurt anybody.
Old 09-02-2018, 10:19 AM   #6
Rewards Points: 516
Ok one more I swear...
I am trying hard to avoid the dreaded corrugated pipe... but I may have no other choice trying to snake through these roots unless I want to seriously crimp the solid pipe. I COULD conceivably get by with multiple angles like some 22.5's connected by straight pipe and screwed together (I can't find sched 35 around here, or at least easily) and put cleanouts on each end, but that sounds like a lot of work. Worst case, would a solid triple wall to corrugated buried underground be a big deal? It would probably get a little extra moist at the junction within those roots, but it is what it is.
Old 09-02-2018, 09:34 PM   #7
Rewards Points: 516
Ok scrap that whole last part. I figured out a way using 2 x 22.5 degree elbows. Still pitches down. I will also do a PVC cleanout nearby.
So the NEW last question. I have the chance to run Sched 35 PVC to connect all these parts as I'd like to glue them. Should I still go HDPE triple wall everywhere else. Besides strength I'm not sure if glued joints while buried are better or worse for long runs. I figure there will be some movement at some point right?
Old 09-02-2018, 10:54 PM   #8
welded HPDE is probably the best you'll get for durability. it's what they use for geothermal systems and those seem to have a solid lifetime.
giansean (09-03-2018)
Old 09-02-2018, 11:39 PM   #9
retired framer
Rewards Points: 54
50 years ago the whole line would have been concrete tile 12" set one in front of the other. the gravel it the main part and to pipe is just a hole in the grave.
Old 09-03-2018, 11:19 AM   #10
Rewards Points: 516
Thank you. I had enough gravel to cover half of the first pipe (used some course sand for the rest) but that was the single. On that note, who thinks it's a bad idea to run a tri-axle filled with 18 yards of topsoil over it? It's 100% triple wall HDPE buried 4-6" in but that might be pushing it. If I put some plywood or just lumber across it would it fly?
Guide to cut down a tree Michae888 Flooring 2 09-01-2017 10:46 AM
Proper Slope for Sump/Gutter Drain dankoos Plumbing 0 05-06-2013 01:59 PM
Replace brass drain in lead pipe hercules2424 Plumbing 2 08-09-2011 01:28 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 10:36 AM
