What Are These Rocks ? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 05-29-2016, 07:32 AM   #1
Rewards Points: 996
what are these rocks ?
yesterday i was drilling a hole for a fence post. it was kinda close, 1 1/2', from a med size tree(if that matters. doubt it). i was having 1 hell of a time about 1' down. a large root that just didn't want to come out. and, i also found these rocks on the hole. the 3 like rocks, they are very light weight. the other is heavy like a rock. also, it is more black than the pic, and right now it is wet, as i just rinsed it off. and it looks like it has some, (for lack of a good description) bubbles in it. this hole is the only place in the yard i have seen these.
Fix'n it is offline   Reply With Quote
Old 05-29-2016, 07:45 AM   #2
Property Mgt/Maint
Rewards Points: 6,538
Re: what are these rocks ?
On the left is most likely slate. And the right appears to be some form of volcanic rock
https://www.google.com/search?q=volc...w=1307&bih=601
Nik333 likes this.
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Nik333 (05-29-2016)
Old 05-29-2016, 08:01 AM   #3
Rewards Points: 996
thats what i was thinking. but slate has some weight to it. this stuff is really light weight.
how the heck would a volcano rock get way over hear. and isn't lava rock also really light weight ?
Old 05-29-2016, 08:59 AM   #4
Rewards Points: 2,583
Flint has sharp edges like that. Could you make an arrowhead out of it?
For the other one maybe something with a lot of iron would give it that weight and dark color.
mathmonger is online now   Reply With Quote
Old 05-29-2016, 09:39 AM   #5
Rewards Points: 4,280
This might help you identify the possible igneous rock on the right.
http://skywalker.cochise.edu/wellerr/rocks/igrocksL.htm
Nik333 is online now   Reply With Quote
Old 05-29-2016, 09:43 AM   #6
From the center of the earth, which you have, too :} Magma becomes Igneous. Glacier movement carried rocks.
There are different kinds of lava with diff. weights.
The one on the left is a sedimentary rock, probably. They vary in weight depending on the pressure that has been on them.
I found some great old Illinois books of rocks on the Internet.
Old 05-29-2016, 06:41 PM   #7
Rewards Points: 1,042
The one on the right could be expanded clay, it's used in light weight concrete as a coarse aggregate, we used quite a bit of it when building the top 50 stories on Sears Tower.
Canarywood1 is offline   Reply With Quote
Old 05-29-2016, 07:32 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 2,192
Although most rocks and minerals come in a variety of forms, I'd vote for shale on the left - flint is usually slightly shinier and not often that dark grey. I agree the one on the right is probably igneous-based and there are thousands of variations. It would be hard to tell without breaking it open to see its interior. The colour suggests high iron content - possibly something called a pyrite concretion.
Nik333 likes this.
lenaitch is offline   Reply With Quote
Old 05-30-2016, 06:39 AM   #9
Rewards Points: 996
so far, the left one = looks like shale. it looks a lot like this on the inside.
i have yet to find an outside piece, so idk bout that.
https://www.dur.ac.uk/images/unconve...ilpicture2.png
i will bust open the other piece ina bit here.
Old 05-30-2016, 07:32 AM   #10
Be gentle in case you have a geode full of amethyst crystals! Unlikely, but for all you know, that could be anything including a small piece of meteor!
Sounds like fun.
Old 05-30-2016, 07:45 AM   #11
Rewards Points: 996
Sounds like fun.
that looks perdy
i had thought that it could be. that would be WAY COOL !
and there were several of these, i just chucked em behind the garage. i will look for them.
Nik333 likes this.
Old 05-30-2016, 07:53 AM   #12
Rewards Points: 996
i just googled meteorites. and there are a few that look pretty darned close.
Nik333 likes this.
Old 05-30-2016, 08:00 AM   #13
Most recent:
http://www.amsmeteors.org/2016/04/il...ril-15th-2016/
The Following User Says Thank You to Nik333 For This Useful Post:
Fix'n it (05-30-2016)
Old 05-30-2016, 09:24 PM   #14
Rewards Points: 996
i now have a bunch more rocks. they are still wet from washing.
the jagged ones are magnetic.
Nik333 likes this.
Old 05-30-2016, 09:57 PM   #15
Wow!
I was reading about black shale that lies over coal beds in your area. Can look gray.
What would make it magnetic?
I wonder what's down there? Be careful, there is uranium in some rocks, I also read. I really enjoy Geology I was fortunate enough to take a course in Hawaii.
Des your state have mineral rights?
Addendum:
"Aeromagnetic surveys are used for geophysical prospecting. Some variations in magnetic measurements are caused by rocks that contain significant amounts of magnetic minerals (magnetite being the most common). These anomalies reflect variations in the amount and type of magnetic material and the shape and depth of the body of rock. The features and patterns of aeromagnetic anomalies can also be used to delineate details of subsurface geology including the locations of buried faults and the thickness of superficial sedimentary rocks." USGS
Cutting Rocks laawaaris Landscaping & Lawn Care 3 02-25-2014 08:15 AM
Using a rototiller with rocks and roots h22lude Landscaping & Lawn Care 8 10-01-2013 08:02 AM
Moving / Lifting big rocks by hand? Thunder Chicken Landscaping & Lawn Care 5 08-24-2011 07:15 PM
how to make waterfall with fake rocks ponch37300 Landscaping & Lawn Care 11 05-22-2009 01:04 PM
question about using rocks pesphoto Landscaping & Lawn Care 2 10-27-2007 02:00 PM
