What Do I Need To Rent To Dig Trenches For 4" Drainage Pipe? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-03-2015, 07:44 PM   #1
Rewards Points: 260
What do I need to rent to dig trenches for 4" drainage pipe?
I need to dig a few hundred feet of trench for landscaping drainage pipe. I'm guessing the trench will need to be around 6 inches wide. The hole won't be very deep. I'm guessing a max of 12 inches.
I might also try to dig a small swale at the edge of my property line.
I thought about renting a ditchwitch, but they seem to only dig 4 inches wide. My other options would be a ride behind trencher or a mini excavator. The excavator seems appealing, since I could dig the swale easier. It seems like it might be overkill for the drain pipes however and be time consuming.
What are your thoughts?
bluefitness is offline   Reply With Quote
Old 08-03-2015, 08:21 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
You can get different width chains for trenchers. Look around at different rental companies and you may find a wider one.
iminaquagmire is offline   Reply With Quote
Old 08-04-2015, 10:36 PM   #3
Rewards Points: 4,406
Much better to rent one of these, in case you have to move dirt, stone, pipe and material.
ron45 is online now   Reply With Quote
Old 08-06-2015, 01:50 PM   #4
JustScrewIt's Avatar
Rewards Points: 284
or one of these...
His name's Nick. As in "a-few-sandwiches-short-of-a-pic-Nick." Ask @Fermenter for his contact info
JustScrewIt is offline   Reply With Quote
PVC or CPVC pipe cement steve3847 Plumbing 7 11-17-2012 05:50 PM
Drainage Pipe w Sock..no rock??? SuzyHomeMaker Landscaping & Lawn Care 7 05-15-2012 09:12 AM
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 08:29 PM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 12:05 AM
Drainage issue from heating system and washing machine susandlynn Plumbing 1 11-17-2007 02:28 PM
