Weedwacker/String Trimmer Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-09-2016, 11:12 AM   #1
Rewards Points: 184
I have a Troy Built TB625EC string trimmer with one of those 4 double string heads on it. The thing is crap. Hard to start and when it does start it runs like crap. To me it doesn't seem to cut worth a damn either - complete junk.
We live in Boynton Beach Florida and have a lot of lawn, so conversely we have a lot of areas that have to be cut with a trimmer along patio/fence/trees/garden. Our "lawn" is about half wild grass and things grow very fast down here. Because we are trying to sell a house in Arizona we have to go back and forth a lot so there are times when the grass is growing for 2-3 weeks when we can't get at it. Can get 6-10 inches high. The riding lawn mower takes care of the lawn - the trimming is what is putting me in the grave.
I need something that cuts good and is light weight. (sorry for this long winded post)
A lot of the weeds/grass we have to trim is along fence and concrete block walls, around trees, etc.
Here are my two main questions - feel free to comment on anything:
1. Because of trimming around hard objects using a trimmer with those hard plastic blades probably would not work - correct?
2. Is there any particular type of string head that cuts better than others.
Splais is offline   Reply With Quote
Old 07-09-2016, 11:34 AM   #2
Rewards Points: 6,128
Re: Weedwacker/String Trimmer Question
I have a smaller yard and encountered similar problems with a name brand power trimmer and switched to an electric version. I have been very pleased at its cutting power and most importantly, it starts every time. I run it on up to 300 ft of heavy power cord but if a longer run was needed I could create an extended power point to work from.
I have followed some discussions on powered trimmers and Echo seemed to get a lot of good comments, but I have never owned one.
Bud
Bud9051 is online now   Reply With Quote
Old 07-09-2016, 02:27 PM   #3
Rewards Points: 6,997
It seems you have multiple problems. They will need to be addressed one at a time.
I have a Troy and when cold it is a PITA to start. I bought a jump starter, battery version and that solved that problem. Running it in choke position 2 enriches the mix enough that once it starts it runs well. Always use Stabil in you gas oil mix.
IMO, all spooling heads are crap. I bought a Shakespeare quick change head and precut my own .095 line to feed the beast. Note that installing this head on a TB trimmer is a fair sized project that requires you making a bushing.
Hardscape and chain link will wear out and break string pretty quickly. I know of no solution other than not hitting it. I can edge 75 foot of beds and only add string once. 80 foot of sidewalk edging can take 20 changes.
The plastic blades are probably not a good ideal.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 07-09-2016, 08:55 PM   #4
Rewards Points: 17,912
Only time I use my trimmer with the plastic blades is when cutting heavy brush and really tall grass,
Hit any landscape stone with it and there trashed.
I've own 2, Stihi FS80R's for many years and have the same power head on a pole saw.
They start every time and have for at least the past 4 or 5 years.
I can swap out the head and use an edger, hedge trimmer, chainsaw.
One way to get out of doing so much trimming is to hit some of those areas with Total Veg, Killer, There's no good reason to have grass growing up and around a chain link fence or landscape stones or even up against the foundation.
I'm mowing and trimming up to 17 yards a week and may only need to replace the line twice a week.
I do all my edging with an edger attachment, not the line trimmer.
Old 07-09-2016, 09:14 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 2,174
My only experience is with Stihl trimmers that run well. I agree that string trimmer heads can be a PITA to reload but I would not use plastic blades. I used to use .095" line on the farm but now that we in a normal house and lot I went back to the lighter line (.060"?). It doesn't take as much abuse but is gentler on trees and things.
Those tiny 2-cycle engines have equally tiny carburetors with tiny passages. They need fresh clean fuel and to be run at or near full throttle. I don't know about Troybilt but most manufacturers are sourcing engines from offshore and many are proving to be garbage. +1 on using Stabil or Seafoam. I know many advocate for using ethanol-free fuel but I have never had a problem with that.
lenaitch is offline   Reply With Quote
Old 07-10-2016, 06:51 AM   #6
Rewards Points: 184
Is there any difference in cutting ability between a head that has 2, 3 or 4 strings; and same question for those quick load heads that have double strings.
Old 07-10-2016, 07:58 AM   #7
Rewards Points: 996
i use that string that is NOT round. it is sharp and cuts real well.
Fix'n it is offline   Reply With Quote
Old 07-10-2016, 10:05 AM   #8
World's Tallest Midget
Mort's Avatar
Rewards Points: 696
I just got a Ryobi 40v electric weed eater. No starting troubles ever. Battery doesn't last too long but during the charge you can drown at least a half a six pack.
I hate signatures.
Mort is offline   Reply With Quote
Old 07-10-2016, 11:50 AM   #9
About how long does it last? Is it fairly light weight?
@Splais As often as I say RTFM it pains me to confess that I have for some time confused the choke symbols on the housing and starting mine with "no choke". Take your air filter off and verify which is open and which is closed.
Colbyt
Old 07-10-2016, 02:43 PM   #10
Mort's Avatar
Rewards Points: 696
Probably about 1/2 hour of heavy use. An inherent disadvantage. But none of the BS associated with a 2-stroke engine.
It's not extremely light but it's well balanced so you aren't nearly as fatigued. And the vibration is way less then a gasser.
I hate signatures.
The Following User Says Thank You to Mort For This Useful Post:
Colbyt (07-10-2016)
Old 07-10-2016, 06:57 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,652
Some of the herbicide will rust a chain link fence, just a heads up. As for the effects of ethanol on small gas engines:
http://www.tractorsupply.com/know-ho...ower-equipment
Or do your own search. I won't use ethanol in any of my small engines.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
string trimmer guard question njitgrad Landscaping & Lawn Care 2 05-13-2015 11:47 PM
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
Repair help w/ a cordless trimmer kennykenny Tools 6 06-28-2009 08:20 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
