Weed Spray - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-02-2017, 03:47 PM   #1
Rewards Points: 300
weed spray
I have a rather large area that we had alot of dirt moved around, and with all the rains past couple weeks, alot of weeds are starting to surface. Our plan is to plant ground cover (ice plant, rosemary, etc...) to avoid erosion, but what and how is the best way to get rid of the weeds cost effective? would a cheap spray do the trick? how soon after the weeds die can a permanent plant be planted?
KPDMinc is offline   Reply With Quote
The Following User Says Thank You to KPDMinc For This Useful Post:
david86camaro (02-02-2017)
Old 02-02-2017, 10:33 PM   #2
Rewards Points: 4,170
Re: weed spray
2% glyophosphate - RoundUp is the best known brand. If anything is still alive two weeks after spraying, spray again. Go ahead and plant once everything undesired is dead.
stick\shift is offline   Reply With Quote
Spray Foam Bad Smell Issues in the Attic Logan176 Building & Construction 2 04-21-2016 02:26 PM
Insulating an Attic - Spray Foam in the Rafters v. Cellulose on the Floor esteve999 Insulation 5 12-13-2014 10:29 AM
dishwasher ddddsmith Appliances 1 09-27-2010 03:36 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
