Weed ID And What To Use To Prevent - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-09-2019, 10:43 AM   #1
Rewards Points: 132
Weed ID and what to use to prevent
Hi All,
I got my sprinkler system fixed and now with all the watering Iím seeing weeds pop up in the grass.
Weed ID and what to use to prevent-img_9057.jpgWeed ID and what to use to prevent-img_9058.jpgWeed ID and what to use to prevent-img_9060.jpg
I always get this onion like grass above.
Early in the season (end of March) I apply a very low dose of prodiamine.
Iíve used weedstop afterwards to on the lawn. But these are still popping up.
Should I be using something else? Stronger dosage? I need suggestions on what I can do or use. Thanks!
007noob is online now   Reply With Quote
Old 07-09-2019, 10:52 AM   #2
DoomsDave's Avatar
Rewards Points: 690
Re: Weed ID and what to use to prevent
Originally Posted by 007noob View Post
Hi All,
I got my sprinkler system fixed and now with all the watering I’m seeing weeds pop up in the grass.
Attachment 563419Attachment 563421Attachment 563423
Attachment 563427
I’ve used weedstop afterwards to on the lawn. But these are still popping up.
The first three pictures are all broad-leafed weeds, which should be (usually) well-handled (killed) by weed killers with 2-4-D in them, like Ortho Weed B Gon (check the label).
That last one is nutgrass, and it sucks. Really sucks. One of the very hardest plants to get rid of. The HUGE trouble with it is that it's hard to kill, period, though there are supposedly weed killers out there formulated to do so, including in lawns. Here's a link. https://www.ortho.com/en-us/library/...ge-or-nutgrass
I don't have a lawn anymore, but I still have nutsedge. Might run out and buy some of that stuff when I get home from The Dark Tower. Be warned; don't just spray and forget. Keep waiting and keep at it. A true Zombie Plant of Doom.
Glyphosate ("Roundup" et al) will kill the tops, but the tuberous roots are very tough to kill. I've found the best remedy is to repeatedly use an eyedropper or the like to put a little straight undiluted 40% roundup in the crowns of leaves. Even that takes multiple applications.
DoomsDave is online now   Reply With Quote
Old 07-09-2019, 10:57 AM   #3
DoomsDave's Avatar
Rewards Points: 690
And here's another link for nutgrass murder: https://www.gardenguides.com/89846-p...rass-lawn.html
Let us know how it goes, @007noob
Old 07-16-2019, 05:43 PM   #4
Rewards Points: 132
Is it ok to apply ortho weed b gone when day time temperature is above 90F?
Old 07-17-2019, 04:58 PM   #5
Rewards Points: 1,482
For anything that grows with a rhizome I use Triclopyr 4. Southern AG Crossbow product has both 2,4-D and triclopyr and so have broad coverage. Triclopyr will not harm narrow leave plants but can harm trees if used within their drip line.
Calson is offline   Reply With Quote
Old 07-17-2019, 07:08 PM   #6
RRH
Rewards Points: 1,584
No because it will weaken a cool season grass. And not very effective on weeds.
That said it is done if you just spot spray.
Best is 85 or below. Above expect 2 applications for close to the same effect.
Forget about the nutsedge especially in hot weather. Anything that will kill it will also kill the grass.
RRH is offline   Reply With Quote
Old 07-19-2019, 10:59 AM   #7
Rewards Points: 132
I looked up ďSouthern AGĒ on Amazon... Would this work without killing the grass:
Southern Ag Amine 24-D Weed Killer, White Bottle https://www.amazon.com/dp/B0072289CA..._vHEmDb0K3R9YQ
I would apply it when the temperature cools down.
