Waterproofing Membrane Installation Against Sloped Foundation - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By homeimproverjoe
  • 1 Post By Bondo
Old 04-08-2017, 01:13 PM   #1
Rewards Points: 616
Waterproofing membrane installation against sloped foundation
Pics included below for illustration. Before I attach the waterproofing membrane to the wall, I want to solicit some advice.
This area will be filled with dirt to near the top of the black membrane that I have laid in position where it will eventually be fastened to the wall. I will be laying a french drain at the bottom of the membrane running to the end of the house to daylight. Should I cut the membrane flush with the ground level or should I create a crease and lay the gravel and french drain on top of it?
I'm planning on fastening the membrane to the wall prior to moving to the french drain project. Just need some advice before proceeding. Thanks in advance. Pics below....
homeimproverjoe is offline   Reply With Quote
Old 04-09-2017, 10:17 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Re: Waterproofing membrane installation against sloped foundation
Ayuh,.... I don't think it'll matter a 'ell of alot, either way,...
Old 04-09-2017, 03:41 PM   #3
Rewards Points: 616
Thanks. Kinda my thoughts too. Appreciate the feedback. Obviously if I can just lay the gravel and drain on top of the folded membrane material, enclosed in some weed block to keep debris from the gravel, it's a much simpler (easy on the back) install than the alternative of cutting the membrane and digging a trench to hold the drain gravel.
BTW, I noticed you preface all of your replies with "Ayuh,....". I suppose it's just your way of talking or does it have a specific meaning?
Nik333 likes this.
Old 04-09-2017, 05:09 PM   #4
Bondo's Avatar
Ayuh,.... It's the dialect of my home, Downeast Maine,..
Been a Maineiac in exile over here in far northern Ny for 40 years, but they still tell me I talk funny,....
homeimproverjoe likes this.
Foundation Repair Company Refuses to Honor Warranty? RSXelrate Building & Construction 3 05-16-2014 06:23 PM
What to put under the waterproofing membrane. TurboDIYer Flooring 22 01-27-2012 09:21 PM
poured foundation wall with infill for raised paver installation 3- 4 feet high mgraniello Building & Construction 1 09-26-2010 09:06 AM
New bathroom installation in old closet with sloped roof and supporting beam Gingerbread Plumbing 0 09-01-2010 01:55 PM
Ceiling Fan Installation - Sloped Ceiling imanerd Electrical 0 06-23-2010 02:00 PM
