Water Spigot Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-17-2015, 05:37 PM   #1
Rewards Points: 35
water spigot question
Kind of weird, but the apartment I live at as a water spigot that is like 2mm larger than the end of the hose I own. So I cannot connect the two together. I don't know if the apartment did this on purpose so tenants can't use them or what. My hose has worked fine in other homes/apartments.
Has anyone seen this before, and if so is there an adapter I could buy (or another hose) that would work? I can't seem to find anything on this on the internet. Thanks for help.
tuffluck is offline   Reply With Quote
Old 05-17-2015, 07:35 PM   #2
Rewards Points: 2,186
Please post a picture of it. Thanks.
jmon is offline   Reply With Quote
Old 05-17-2015, 10:50 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
And where are you?
Old 05-18-2015, 02:23 AM   #4
Rewards Points: 6,652
Most likely it was done that way, for commercial hose sizing, that would be used by landscaping companies. Standard is 5/8", the larger sized is 3/4".
2 water heater tanks parallel question dumbengineer Plumbing 16 05-10-2014 09:35 PM
Shower water supply question YoungRascal Plumbing 3 03-15-2013 10:37 AM
water softener install/manifold question climbhigh1119 Plumbing 10 03-07-2013 11:36 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
