Water Seepage Into Basement - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-30-2016, 02:38 PM   #1
Rewards Points: 2
Water seepage into basement
During very heavy rains over a few days span I'll get water coming in around my basement door. I attached a picture of the grading. Would it more worthwhile to put in a French drain or see about regrading this area?
Water seepage into basement-image_1459366645492.jpeg   Water seepage into basement-image_1459366674303.jpeg
Donedeal is offline   Reply With Quote
Old 03-30-2016, 02:39 PM   #2
Rewards Points: 258
Re: Water seepage into basement
regrade would be the best, does any part of your property go down hill from that location?
woodchopper65 is offline   Reply With Quote
Old 03-30-2016, 02:42 PM   #3
Rewards Points: 2
Theres a leveled area and then a subtle gradient after that. I'll look into landscapers for regrading. It happens so infrequently I wouldn't want to sink a lot of cash into the job.
Old 03-30-2016, 02:51 PM   #4
Rewards Points: 258
the cheapest way would to remove some soil grading away from the door to the lower area and then gravel back over it..
Old 03-30-2016, 02:56 PM   #5
ZTMAN's Avatar
Rewards Points: 342
Based on the pics showing the way the brick courses are aligned around the door opening, I assume some one cut the door in well after the house was built and didn't feel like cutting bricks . Looks like they dug down to get the door opening to fit. You should get rid of the ditch.
ZTMAN is offline   Reply With Quote
Old 03-30-2016, 04:24 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,.... It's Obviously pitched right into the doorway, lookin' at the brick lines, 'n concrete reveal on the other side,.....
Regradin' is the Best fix,....
Old 03-30-2016, 06:00 PM   #7
Rewards Points: 17,912
Looks like someone was trying to form a funnel to direct all the water toward the door.
What happened to the threshold under the door?
No doors threshold should be any closer then 2" of the grade.
Old 03-31-2016, 08:13 AM   #8
dd57chevy's Avatar
Rewards Points: 2,732
I would agree with the grading viewpoints . Not sure there's an easy fix here . That door (as is) may be causing more problems than it's worth . A couple of questions :
1. The BIG question is : Is this the only access to the basement ??? If not , I'd think about eliminating it & restoring the foundation and a proper grade .
2. Is there a pressing need for exterior access to basement , ie: firewood , other ??? If so , maybe an old mode coal/firewood door (w/out stairs , not designed for foot traffic).
Unless you live in a "code-free" zone , I doubt you can put in , say , a 70" (short) door !
dd57chevy is offline   Reply With Quote
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Not another basement water "management" thread! mwpiper Building & Construction 11 02-06-2012 07:31 AM
Water in Basement. One last Question. daltinator Building & Construction 8 01-25-2012 11:59 PM
crawlspace slab voids, basement water geoffmiller Building & Construction 0 11-25-2011 09:01 AM
