Water Pooling Beside Patio - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-26-2019, 09:20 PM   #1
GBunny
Rewards Points: 79
Water pooling beside patio
Had a patio install two years ago. I know we have had a very wet spring and the ground is totally saturated. After a heavy rainfall, there is about 2 inches of water pooling beside the patio and along fence.
There is only a 6 inch gap (or less) between edge of patio and fence. Not much room for drainage although I do have small stones there but it is overflowing on top of them. I don't think there is enough room for a French drain. What else can I put there?
GBunny is offline   Reply With Quote
Old 05-26-2019, 10:21 PM   #2
GBunny
Rewards Points: 79
It's very difficult to see the water. It's easier to just see the reflection in the water under the fence
Old 05-26-2019, 10:35 PM   #3
JUSTA MEMBER
Rewards Points: 4,026
Re: Water pooling beside patio
Ideally, the contractor should have built a drainage system in there to take the water away.
See if they have a satisfaction warranty, and make them repair this hazard.
Otherwise, have a drain put in to channel the water to a lowlands, or the storm drainage system in your community.
ED
de-nagorg is online now   Reply With Quote
Sump pump cannot keep up with very heavy rains - please help rjlee Plumbing 32 02-02-2019 11:45 PM
Black smelly water Gradydane Plumbing 3 11-30-2018 08:42 PM
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
