Water Marks On Stained Fence - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Joeycarnuba
  • 1 Post By CaliBoarder
Old 05-10-2017, 12:05 AM   #1
Water marks on stained fence
Does anyone have an idea what went wrong on fence panels? It's a solid stain on kiln dried redwood. It was put up for 2 weeks and recent rain storm left some type of water marks. Not sure if it goes away with time.
Water marks on stained fence-img_4854_1494392602585.jpg   Water marks on stained fence-img_4853_1494392693992.jpg
CaliBoarder is offline   Reply With Quote
Old 05-10-2017, 05:34 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,608
Re: Water marks on stained fence
Looks as if the top of the rail wasn't well enough sealed and moisture got into the wood and is bleeding through.
Old 05-10-2017, 02:46 PM   #3
Rewards Points: 122
The fact that it gets darker on the lower boards makes me think the top boards were dirty and the dirt just ran down the board and then dried in place. Maybe it wasn't enough rain to completely wash the dirt off. Have you tried hosing it off or lightly pressure washing it?
Mike Milam likes this.
Joeycarnuba is offline   Reply With Quote
Old 05-10-2017, 11:21 PM   #4
I called Olympic paint and tech guy said it's called tanin, Something to do with moisture trapped inside wood, common with redwood and cedar. Not sure about moisture in panels since there kiln dried. Anyways tech said to try soap and water. Will try over weekend and update if it works.
Old 05-10-2017, 11:38 PM   #5
Gonna try Dunn Edwards primer on the rest. Wish me luck!
Dave Sal likes this.
Old 05-12-2017, 05:48 PM   #6
Rewards Points: 302
how long did you let the boards dry out before applying the stain?
KPDMinc is offline   Reply With Quote
Old 05-14-2017, 12:56 AM   #7
Fyi, the water and soap took off the tannin marks. ??
Help with hot water katiejosh811 Plumbing 13 12-28-2016 05:52 AM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
